speedo gear?
  • Thread starter Thread starter Roland69
  • Start date Start date Feb 24, 2006
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Feb 24, 2006
  • Feb 24, 2006
I have 3:55 in my 88 GT and I need to know what speedo gear to get. I did a search and read that they changed what speedo gear neened for certian years and trannys. I have a stock T5 in my 88.
L
llwood
39
  • Feb 24, 2006
call your local dealership and tell him what you got and he can order you the right one. Mine was all of about 13 bucks or something
M
Mike92GT
583
Florida
Feb 24, 2006
  • Feb 24, 2006
Read this, should help
http://www.geocities.com/mgnedell/notchback/tech/speedo.html
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Feb 24, 2006
  • Feb 24, 2006
thanks for the link I need a black 20 tooth gear.
timewarped1972
642
mesa, az
Feb 24, 2006
  • Feb 24, 2006
yep, if your certain it's an 88 t-5 thats the gear, the black 20 tooth. www.50resto sells it to for $7.95, but they sometimes bend ya over a little with shipping on small stuff........you'd have to call and check..
Chowder Head
155
Tampa, FL
Feb 24, 2006
  • Feb 24, 2006
Don't mean to hijack, but I have a speedo related question. I have a 95 GT with 3.73 gears. Now I know that the white 23 speedo gear will be the closest without changing the drive gear but exactly how off would it be? 1-2 mph? If it's something that minuscule, I won't bother.
But if I really wanted to change the drive gear, how hard of an install are we looking here?
Thanks!
timewarped1972
642
mesa, az
Feb 24, 2006
  • Feb 24, 2006
just changing the speedo gear is easy, on the driver side of the tranny towards the rear the speedo cable and vss sensor go into the tranny. one bolt, you pull the sensor/speedo gear out, pop off a clip, put new gear on, re install.
the problem witht he 90 up aod's and t-5's is the actual gears in the tailshaft of the tranny only accomodate up to a 3.55 speedo gear. what happens is if you use another gear it can or i should say will slowly chew the speedo gear up.
i did that with my old aod. i put 373's in, used the closest gear that would work for it, and when i did my t-5 swap and pulled the gear out it was chewed, still worked, but wouldn't have for much longer, and that was with only 1000 miles on it...
i'm not positive if thats the same with the 95 or not.......meaning, i don't know if there's a gear you can use thats just not as accurate, but will mesh ok, or, if it's the same deal, where if you use a 3.73 speedo gear it will work but eventually get chewed...
to totally fix it, you can buy the correct drive gear for inside the tranny itself and use the correct gear........how difficult that is to do i couldn't tell you......
i'm guessing it will be off by more than 1 or 2 mph, and that will get more innacurate the faster you go...
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 24, 2006
  • Feb 24, 2006
I've swapped the drive gear twice on mine -- both times with the tranny out of the car. You have to remove the shifter, drive out the pin on the shift shaft allowing you to remove the tail shaft housing. Then it's a simple matter of removing the retainer clip and sliding the new drive gear on. I'd suggest you use a new retaining clip when you replace the drive gear. You'll want to go down in the number of teeth on the drive gear -- if you have an 8, go to a 7; if you have a seven, go to a six. Use the link above to determine what driven gear you need to go with a smaller drive gear.
bill302
2,131
alabama,gadsden
Feb 24, 2006
  • Feb 24, 2006
i have a 20 tooth black speedo gear it's in good shape i'll sell for an even $10 shipping included pm me.
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Feb 24, 2006
#10
  • Feb 24, 2006
  • #10
Ummm... I had 3.55's and got the red one... no freakin wonder!
squeeeg
1,905
Michigan
Feb 24, 2006
#11
  • Feb 24, 2006
  • #11
tech.stangnet.com
The info is on there. You need the black 20 tooth gear.
EDIT: stupid typos
timewarped1972
642
mesa, az
Feb 24, 2006
#12
  • Feb 24, 2006
  • #12
squeeeg said:
tech.stangnet.com
The info is on there. You need the black 30 tooth gear.
i think thats 20 tooth.....
you know theres been about 3 or 4 speedo gear questions like this in the last week, i'm so confused as to who's cars what year with what tranny needing what gear.............vote for speedo gear sticky
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Feb 24, 2006
#13
  • Feb 24, 2006
  • #13
This spells it out pretty clearly...
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Drivetrain Autometer Speedo Cable for T5
  • cbac89
  • Feb 15, 2025
Fox 5.0 Mustang Tech Feb 15, 2025
AeroCoupe
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
