  • 1994 - 1995 Specific Tech
speedo off
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Sep 21, 2007
DDSTANG94
465
FRASER, MICHIGAN
Sep 21, 2007
  • Sep 21, 2007
OK guy i put a new trans in dorm D and D, and after my speedometer seems to be off by like 5 mphs. Is it the speedo gear causing my problem. i noticed the new trans was a tremic.. how many teeth does the stock speedo gear come with in the 1994-1995 t5's....??? thanks people
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Sep 22, 2007
  • Sep 22, 2007
Tremec bought the transmission division from Borg Warner sometime in the late 90's, so that's why the case says Tremec on it. How many teeth are on the driven gear inside the transmission? D&D may have sold you a transmission with a different tooth count than the factory 8 tooth drive gear. Give this thread a look, it's got some good info: http://forums.stangnet.com/showthread.php?t=646803
DDSTANG94
465
FRASER, MICHIGAN
Sep 22, 2007
  • Sep 22, 2007
wow .....im lost
BlownFiveLiter
18
108
Chicagoland
Sep 22, 2007
  • Sep 22, 2007
Alright, I'm assuming you got another T5, right? Give D&D a call and ask them what speedometer drive gear they installed in your transmission. From the factory, it would have had an 8 tooth gear, but they may have installed a 7 tooth gear, which would throw your speedometer off. Just an example:
Say you have stock 2.73 gears. From the factory you'd have an 8 tooth gear in the trans and the yellow 18 tooth gear on the speed sensor to calibrate the speedometer. If they installed the 7 tooth gear in the transmission, you'll need the maroon 16 tooth gear to get you back to the same place. With the 18 tooth gear on the speed sensor, you'd be calibrating the speedometer for a 3.08 gear with the 7 tooth gear.
It's pretty easy to figure out, but you need to know which gear is installed in the transmission in order to figure out what gear you need on the speed sensor. If they installed the wrong gear, I'd ask them to send me the correct gear at their cost, to correct the speedometer. It's their fault they're not installing the factory part in the transmission and screwing up your speedometer, right?
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
New here , too many cars and too many problems
  • spencergt66
  • Mar 19, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 21, 2026
spencergt66
