  • SN95 4.6L Mustang Tech
speedo problem
  • Thread starter Thread starter slickrick812
  • Start date Start date Jan 16, 2006
slickrick812
Alabama
Jan 16, 2006
  • Jan 16, 2006
My speedo quit reading millage on my 96 mustang gt. i was told it was the speedo head and would cost a lot of money to replace. can i buy an aftermarket speedo head and cluster and set the millage to what my car reads?
nyuk98gt
1,427
Chesterfield, MO
Jan 16, 2006
  • Jan 16, 2006
slickrick812:
If you are handy, you can replace the little speedo gear yourself. The pre-98s had a problem with too little grease on the gears leading to premature failure. Check "carradio.com" for new gears -- they are pretty helpful.
edit/// OK, if it is just the odo or speedo, then it is probably one of the little internal gears. If both are not working, you can check the vehicle speed sensor (VSS). Crawl under the car and you will see the VSS plugged into the transmission at about 10 o'clock on the driver's side. It is held in with a single bolt (don't over tighten it when you reinstall the VSS!!!). Unplug the connector, remove the VSS. Plug a voltmeter in on AC (yes, alternating current) and spin the gear by hand. The voltmeter should register voltages (+/-). If nothing, then you know the VSS is shot. It may just be the driven gear on the VSS. If it is toothless, replace it. The stock gear is orange (21 teeth, if I recall correctly) for a 3.08 rear. The 'carradio.com' guys will fix the cluster for you, if you send it to them (they are in Richmond, Virginia).
end of edit///
HTH,
Chris
sgarlic
3,085
Jan 16, 2006
  • Jan 16, 2006
You could probably find a used or pretty new one on ebay or at a junkyard for cheap. Yea, it'll screw up your mileage, but who cares.
merc123
420
North GA
Jan 17, 2006
  • Jan 17, 2006
it would suck if he tried to sell the car though.
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jan 17, 2006
  • Jan 17, 2006
If the speedo still works, but the odometer quit LOOK HERE
EDIT: gear was $25
If it's both, I agree with nyuk98gt.
sgarlic
3,085
Jan 17, 2006
  • Jan 17, 2006
Depends how you look at it. Putting aside the ethical and moral dilema of odometer tampering, here's an example...
The previous owner of my foxbody told me the odo was wrong.. the title said it had 119,000 miles, but the odometer said 66,000 something or other.
I swapped instrument clusters 3 or 4 times before I sold it, and when I did, the cluster I put in last was showing around 30,000.. probably about the correct number of miles according to the title (assuming I drove it around 20k which is probably correct.)
D
Speedo and tach dead
  • Davinrobinson1
  • Jul 19, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jul 26, 2026
fasterthangas
F
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
