Speedo Problems - ive searched forum
I'd start with a new cable, it may be getting hung up somwhere in the line, i think it's only like 30 bucks or so, if that doesn't fix it goto ebay and get another speedometer.
I'll assume since you changed the speedo sensor that you checked the speedo gear for stripping.
Mine used to bounce under 45mph but last night it snapped. 2mo. out of warranty! :bs: I have changed it two or three times, it is a piece of cake, just a pita.
Anyway, i think the problem with mine was that imediatly after the sensor the cable hits the exhaust hanger for the h-pipe. That is where it binds cause that is allways were it breaks. I have to shave down the hanger some to get the clearence. Check yours next time you are under there. That could be your problem too.
Will I just be able to open up the dash, disconnect cable from the instrument cluster, pull it up and out. Then slide new cable down into casing? Should this take care of the bouncy speedo? Or do I need to change the speedometer housing too?
You wouldn't believe how hard it is to find a speedometer cable. Ford, Carquest, and O'Reilly do not have it. I found one at the local Napa and also at Advance Auto Parts. And of course LRS has one.
I have about 75% of the dash apart, just have to take out the pod and then the instrument cluster to get to the speedometer cable. I am going to pull the cable out, clean it and check it out for any burrs, etc. Then if nothing is visible, I am going to relube it and slide it back in. I am going to reassemble enough to go for a drive and see if the needle isn't shaking. If it is, I'll pick up the new cable/housing and do the full install on it.
From Jinchers (sp) , It looks like the end just pulls out of the transmission mount and then reroute the new cable the same way as the old one with the holders. Sounds like fun:D
While I'm there, I am taking the fuse panel mount out and having the crack in it welded or a new mount cut out at the local welding shop.
I'll let you know what happens on the cable. Thanks again Stangers:nice:
I got the cable out and all wiped down and was getting ready to relube it and then I saw it. The plastic end that goes into the Speedometer has 3 small cracks that start at the base and go toward the point about 1/4". I don't know if this was the cause of the bouncy needle or the fact that there was very little grease on the cable, but I might as well put in a new cable. Off to Napa in the morning. Will decide then if I will change the housing too, but I probably will.
Got it Done
I replaced the casing and the cable and now no more bouncy speedometer. Everyone's instructions were very helpful.
I did have some minor problems. When I pulled the old cable from the VSS it pulled the casing apart from the end. A simple pull on the end with pliers and it came right out. The string I tied to the cable to pull the new through wasn't strong enough so it broke. But with a little fishing I got it thru the grommet and hooked up.
I'm going to split some rubber fuel line and cover the casing where it runs under the floor pan. It crossed under a couple sharper parts of the undercarriage and might as well try to prevent any future rubbing.
While I had the steering column cover apart I also replaced the deteriorating foam circle that goes around the turn signal lever. I just took an air conditioner foam filter, cut out 2 circles and glued them together to give them the correct thickness.
Thanks again:flag:
