Speedo wrong?
MyCARneedsHelp
658
Plainfield,IL
Ok so im driving down a busy street and everyone is passing me. I called my gf and had her follow me and im going slower then what my speedo is telling me
So if my speedo says im going 40 im accually going about 32-35mph anyone know what is involved with this so i could look at it? im guessing my speedo cable? :shrug: Thanx for the help
I just changed gears 2.73's--3.73's.when 60 my speedo says 85.theres a cable that goes into the tranny,pull it out and theres a little gear on the end.First you have to find out you rear end gear ratio, you have and put the correct gear on the end of the cable.Depends if you got a 5speed or aod to find the correct little gear you need.
I just got the last gear in stock from Summitt,but they got it from TCI.I have an aod also,its the 23 toothed gear!! There easy to find.Call up tci or theres alot of different places you can get one.19.00 bucks !!
hey guys im having the same problem i was probably going 60 or a little more and my speedo was saying that i was going 80 i have a 93 lx i dont know what kind of gears it has really its a AOD with a shifter so which speedo gear will I need? how can i check what gears I have?
Jack the rear of the car up on jackstands and place the transmission in neutral. Make a paint mark on the rear part of the driveshaft that is visible from the side of the car. Make a mark on the tire, and rotate it one turn while counting the number of turns the driveshaft makes.
less than 3 turns of the driveshaft = 2.73:1
about 3 turns and a little more = 3.08:1
a little more than 3 1/2 turns = 3.55:1
almost 3 3/4 turns of the driveshaft = 3.73:1
a little more than 4 turns of the driveshaft = 4.10:1
See http://www.geocities.com/mgnedell/notchback/tech/speedo.html for information on speedo drive gears.
see http://www.corral.net/tech/gearcalc.html for a calculator that uses RPM, rear end ratio and tire size to calculate speed
The best way is to mark the driveshaft, turn the rear wheels 10 times, count the number times the driveshaft rotates, then divide that number by 10.
When you turn the wheels only once, it's hard to tell the difference between 3.08 turns of the driveshaft and 3.27 turns (or 3.55 turns and 3.73 turns, etc.). I know this for a fact. I thought I was getting a 3.08 rear end and really wound up with a 3.27 (even better). Only after I took off the differential cover and counted the pionion and ring gera teeth did I discover the error.
