You cannot get a speedometer gear with enough teeth to compensate for the 4.10 gear ratio on the t-45. THe highest possible speedo gear is a 23 tooth which compensates up to a 3.55 gear.
To get the speedo accurate- I would get the Dallas Mustang speed cal
http://www.dallasmustang.com/index.mvc?Session_ID=6a5140af0bbde7114b37f2b1c30dd1a3&p=9910
This way, he can correct for the gear change and any future tire diameter changes.
Plus, it is a very simple install- you only have to splice into one wire.
