speedometer gear.. 3.73??
  • Thread starter Thread starter MUSTANGJOE
  • Start date Start date Mar 27, 2004
MUSTANGJOE
Silver Stanger
1,644
17
59
Mar 27, 2004
  • Mar 27, 2004
Just got 3.73 gears.! Cant wait to put them on. Anyone know the size of speedometer gear i have to buy? 5.0 resto doesnt seem to have for my year 1992. If someone could give me a link or witch one to buy I would appreciate it. Thanks again guys
M
myroc
120
  • Mar 27, 2004
23 tooth gear.I think BBK makes them.
willys1
1,004
New Jersey
Mar 27, 2004
  • Mar 27, 2004
Yup,I put 373's in my stang back in December.I have an aod,and used a 23 toothed gear that I ordered from Summit( 19 bucks) 3 months old and it works great!
T
TattooMatt
72
GA
Mar 27, 2004
  • Mar 27, 2004
It's a white gear for the T-5. I think 21 tooth
MUSTANGJOE
Silver Stanger
1,644
17
59
Mar 27, 2004
  • Mar 27, 2004
Antone have the link for summit...I checked on the web site but cant find speedometer gears..what do I look under? My car is a 5 speed does this make a difference?
so is it 23 or 21 toothed? Thanks
R
rockin_rick
968
Mar 27, 2004
  • Mar 27, 2004
A 92 T-5 has a 8 tooth drive gear in the tailhousing. A 23 (white) will get you close, but not dead on. 8/23 is dead on for 3.55's. To get dead on, you need to swap the 8 toother for a 7, and run a 21 on the sensor. Most people with 8 tooth drive gears and 3.73's will run the 23. Your speedo AND your odometer will read higher than actual. More miles will record on your car than you are actually putting on. That kinda sucks.
23 is the largest made. Because of that, the teeth are thinner and more prone to breakage. Ford doesn't make any 23 toothers. 21 is the highest they go.
Rick
T
TattooMatt
72
GA
Mar 27, 2004
  • Mar 27, 2004
What tranny do you have? The one for a 90-98 T-5/AOD is 23 tooth. (21 tooth is for 3.27 my bad)
Steeda has them and you can also get them here Gene Evans Ford
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Mar 27, 2004
  • Mar 27, 2004
Try this and see if there's an answer for you:
http://www.geocities.com/mgnedell/notchback/tech/speedo.html
R
rockin_rick
968
Mar 27, 2004
  • Mar 27, 2004
http://www.ddperformance.com/speedo_gear_chart.htm
The formula used on this webpage is the same one that's in the Ford Racing catalog.
After looking over this info again, I'd suggest the 6 and 18 for the compatibility with other common ratios. This is, of course, if you are going to change the drive gear. There is a pretty good match for each common ratio, so if you were to change later, you wouldn't have to change out that internal gear again.
Rick
willys1
1,004
New Jersey
Mar 27, 2004
#10
  • Mar 27, 2004
  • #10
Again,I have a 93 LX aod,373's and the white 23 tooth gear,my speedo is dead on accurate.Call the 800 #,its much easier. 1(800)230-3030.
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Mar 27, 2004
#11
  • Mar 27, 2004
  • #11
Switch to a 6T or 7T drive gear and the appropriate driven gear or expect the speedometer to be anything but 'dead on accurate' with an 8T drive gear.
MUSTANGJOE
Silver Stanger
1,644
17
59
Mar 28, 2004
#12
  • Mar 28, 2004
  • #12
are the 8 teeth drive gears hard to change?..So If I get a 7 tooth drive gear I would go with the 21 tooth right? and If I stay with the 8 I go with the 23 to be the closest?
R
rockin_rick
968
Mar 28, 2004
#13
  • Mar 28, 2004
  • #13
To change the drive gear, the trans tailhousing needs removed. Never done it myself.
yes - 7 and 21 OR 8 and 23 (OR 6 and 18).
Rick
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Mar 28, 2004
#14
  • Mar 28, 2004
  • #14
I've done it - and on my car the tranny has to come out. I don't have enough room through the shifter hole in the floor to drive the pin out of the shifter shaft. The tailshaft housing of the tranny has to come out. I suspect even if you could release the shiftershaft with the tranny in the car, getting to some of the top bolts on the housing would be a pain in the rear. Of course tranny out means exhaust system and driveshaft have to go. It's not complex, but it is time consuming.
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
