Speedometer Issue
  • Thread starter Thread starter warrenbh
  • Start date Start date Feb 28, 2010
warrenbh
35
  • Feb 28, 2010
I have a speedometer that grossly understates my speed. If i'm on the highway moving with the flow of traffic (no jams), the speedometer tells me i'm going 35 when it should say something closer to 65-70.
Do i need a new speedometer or is this a simple fix on a 66 mustang gt.
Thanks in advance for any responses.
tx65coupe
Mar 1, 2010
  • Mar 1, 2010
All you should need is a different speedometer gear. It goes on the end of the speedo cable at the transmission and can be changed out in a few minutes. I bet the car does not have the original rear end gears and/or has larger rear tires.
Before you buy a speedo gear, you need to know what the rear gears are and what size the rear tires are.
D
D.Hearne
11,730
south louisiana
Mar 1, 2010
  • Mar 1, 2010
Did it just start doing this on it's own? Without your changing the rear gears ? Or tires ?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Mar 1, 2010
  • Mar 1, 2010
Um, yeah, before you rip it apart, is the odometer accurate? Use the mile markers at the edge of the road. Chances are though, you will need a different driven gear on the end of the cable.
calpolymustang
217
Santa Rosa, CA
Mar 3, 2010
  • Mar 3, 2010
if the rear end is a lot different that stock type ratios, you may need a gear reduction device that plugs into the tramission.
when i added the 4.11s, i had to get a gear reduction since speedo gears with more than 21 teeth dont last long before wearing out.
68RCodeConv
345
Houston, TX
Mar 4, 2010
  • Mar 4, 2010
He does not need the gear reduction. That is for when the speedo reads HIGHER than actual speed. He needs fewer teeth on his speedo gear to "speed up" the speedo.
That being said, I have never heard of a speedo reading that low (almost 50% low). If you currently have a 20 tooth gear then it means you would have to go to something like a 12 tooth gear which does not exist.
I suspect something is wrong with the speedo.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
