I have checked the connection in the back of the cluster, checked fuses, and replaced the vss and still nothing...but everything else works fine on the cluster except for the speedometer/tripometer. Idea's anybody?
1Bad89Coupe said:I don't think its the cluster because everything else works fine and the way it should![]()
bimmertech said:your speedo and tach are its own seperate unit, so the rest of your cluster may work and this may not.
get a donor part to test it.
How do you get the printed circuit off the back of the cluster? I need to change my odo gear.Jinx102672 said:For your Odometer and trip meter, did you check the small plastic gears for missing teeth?
gmkillr said:I dont think the gears being bad will make the speedo not work. My bet is that the circuit board is bad, its the same exact problem im having.
The Green GT said:How do you get the printed circuit off the back of the cluster? I need to change my odo gear.
gmkillr said:I did some research and found out that an 03 gt cluster wont even plug into our cars so forget that one. Now I got to find somebody local w/ a 94-95 v-6, gt, or a cobra.
