go-stang5.0
how did you check the VSS? Did you try to stick your finger in the VSS hole (on tranny) to see if the speedo drive gear is in the right place. When I put a 23t driven gear in it chewed up and moved the drive gear to a spot where no gear would contact it. I would stick your finger in there and make sure it hasent shifted from its proper spot...it only takes a sec.
