speedometer
  • Thread starter Thread starter 86mustang5.oh
  • Start date Start date Aug 12, 2005
86mustang5.oh
125
battle creek mi.
Aug 12, 2005
  • Aug 12, 2005
ok i put in a new speedometer cable and my speedo still doesnt work any ideas
bubba-dough
1,044
Indiana
Aug 12, 2005
  • Aug 12, 2005
Make sure the cable didn't pop off while putting it back together. I have had a time with them either not staying on or sometimes I can't get them off the speedo itself. Check the speedo gear that goes into the tranny. Make sure it isn't stripped. Then I would assume its the speedo.
Just my opinion. I hope this helps.
M
mr.b
214
  • Aug 12, 2005
put the car on jack stands, take out the speedometer and then start the car. Put it in gear and let the wheels turns. Then u can see if the speedo cable is actually spinning inside the sheath. This way you can see if it is related to the drive gear, driven gear or the cable and not the actual speedometer.
then go from there. I have found that if the needle is not pressed on the speedo shaft hard enough, it will sit there and ride on the shaft that turns it and makes it read.
or, i have taken the end out of the trans. chucked it in a drill and tried to spin it that way. but that wont tell you anything about the drive gear in the trans.
any more questions, let me know. I have spent alot of time here recently messing with my speedo, gear and cable.
86mustang5.oh
125
battle creek mi.
Aug 12, 2005
  • Aug 12, 2005
yea it doesnt move i took my cluster out and drove it around and nothin it doesnt spin any ideas
M
mr.b
214
  • Aug 12, 2005
Take the cable end out of the trans. and look to see if the teeth are stripped off the plastic gear. If they look fine, stick your finger in the trans. and see if the teeth on the drive gear feel fine (put it in neutral and rotate the driveshaft so you can feel the complete gear. If this all looks good, take the little plastic gear off the end of the cable (held on by a little c clip the you just pull off) and look inside it and see if you still see a square socket in the plastic for the metal cable to go into. This could easily round out and the gear would just spin around the cable and not actually engage and spin the cable itself.
notchback
1,950
St Clair Shores MI
Aug 12, 2005
  • Aug 12, 2005
i'm certain it's the speedo gear in the trans
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
C
Resolved Dead speedometer... not odometer gears or trans speed sensor 4R70 W
  • cobramoneypit
  • Jul 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 22, 2026
cobramoneypit
C
T
Drivetrain Can’t identify correct speedometer gear
  • townethug
  • Jul 12, 2025
Fox 5.0 Mustang Tech Jul 21, 2025
FastDriver
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
