spindle length '68/'69 vs. '70
  • Thread starter Thread starter cougar_68
  • Start date Start date Apr 18, 2004
cougar_68
849
Garrett, IN
Apr 18, 2004
  • Apr 18, 2004
To skip all the mumbo jumbo, go to where it says, "cut to the chase..."
I recieved a set of spindles with a disc brake conversion kit hat I bought for my cougar. The guy told me they were '69 spindles. I went ahead and bought all my brake stuff for a '69; rotors, calipers, bearings, seals, etc... Well the bearings wouldn't go on, so I was like, "Now what??". So I went and got new bearings thinking I bought the wrong ones. Those didn't fit either.
Then I went back to the parts store with the old junk bearings that came with the conversion kit. Turns out the bearings that fit are for a '70 mustang. So I brought those home, greased them up and tried to assemble the bearings and rotor. The spindle was too short.
CUT TO THE CHASE...
Is the spindle on a '70 shorter than a '69? Thanks!!
R
Ronstang
1,294
Houston Texas
Apr 18, 2004
  • Apr 18, 2004
Nope....it isn't shorter....the shaft is larger for increased safety, hence the bearing not interchanging. You have better spindles so rejoice!!!
cougar_68
849
Garrett, IN
Apr 18, 2004
  • Apr 18, 2004
I read something about smaller/larger bearings on a '69 spindle. Does that mean that the larger bearing '69 spindle is the same as the '70 spindle?
R
Ronstang
1,294
Houston Texas
Apr 18, 2004
  • Apr 18, 2004
I've never heard of the larger bearing '69 spindle.....if it exists it is just the '70 spindle being used before the '69 modle run was up.
cougar_68
849
Garrett, IN
Apr 18, 2004
  • Apr 18, 2004
I just found it, it was in the mustangs plus catalog. It does show the same part number for the rotor, so the new rotors I ordered should work fine.
I'm glad it is stronger, but It kinda sux that I have to sell the other rotors and I don't know how much I can get. They are $95 new from AutoZone. Will probably put them on ebay.
bnickel
5,640
lubbock, texas
Apr 19, 2004
  • Apr 19, 2004
the larg bearing 69 spindle was for bosses and shelbys. check the part number that may be what you have
mustang70
2,445
San Diego
Apr 19, 2004
  • Apr 19, 2004
Why can't you take them back and tell them you got the wrong ones? You still have the reciept right?
cougar_68
849
Garrett, IN
Apr 20, 2004
  • Apr 20, 2004
Well, I've had them for a long time. I'm not sure where the reciept is. Also, they were "special order" and they don't take returns on "special order" items.
I looked for a part number on my spindles...guess what...D0**. I could remember the last to numbers, it might have been D0AZ, but anyway D0=70 so that solves that mystery.
On a good note. I got my '70 rotors today and put one on the car along with an empty caliper to see if my 14" torq thrust would fit. Wasn't I suprised...so far the only thing that has gone right...THEY FIT!!!
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
