Spindle Swap 2003-1992
They will swap with your spindles. You just need a 5/8" ID spacer, about .330" thick. Hardened washers will work.
Or, change out the balljoint to an Sn95 style ball joint.
Just keep in mind, 96-04 spindles do push the front wheels out 8-10mm more than 94-95 spindles, and the suspension goemtery is not ideal for a Fox. 94-95 spindles are preferred
