splutter
lrmccoy
i have a 1985 ford ranger with 87 mustang running gear, aod tranny 373 gears,my problem is when i get on it , it will reu good for about 2 sec then it almost dies then it really comes on strong the truck was a 4 cyl. and t have a in line 35 lb. to 45lb fuel pump, the truck has no pump in the tank it was carb. 4 cyl. it has a inline fuel filter, at idle it has 40 lb fuel pressure. i need help thank you lrmccoy.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
index.php
index.php
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
