spring isolator???
  • Thread starter Thread starter slayerripkdc
  • Start date Start date Jul 17, 2010
slayerripkdc
1,341
brewster ny
Jul 17, 2010
  • Jul 17, 2010
Is it a PITA to remove spring isolators. I currently installed h&r ss springs about 6 months ago on 99-01 17 inch cobras. After they settled I would like them to just be a tad lower.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jul 17, 2010
  • Jul 17, 2010
No, all you need some "stiff knees" to put the car up and two hydraulic jacks. The spring compressor; that the guides reccomend, looks dangerous to me, just raise the jack to compress the spring, then lower the jack SlOWLY when you unbolt the attachments.
04GreyGtUSAF
43
KS
Jul 19, 2010
  • Jul 19, 2010
I took my isolators out when i put in my c-springs. I bought 3 rools of the all weather 3M electrical tape and wrapped the springs with a few thick layers to avoid possible squeak.
Flghtmstr1
572
Springfield, PA
Jul 19, 2010
  • Jul 19, 2010
If you installed springs about 6 months ago, wouldn't you know whether removing the isolators is a PITA or not?
Night Shifter
Well-Known Member
Dec 24, 2005
1,710
27
59
Daytona
Jul 19, 2010
  • Jul 19, 2010
EASY!
1. jack up car
2. put jack stands under car
3. take off wheel
4. unbolt caliper
5. unbolt swaybar endlink
6. place jack under control arm
7. unbolt shock from spindle (leave top bolted in)
8. lower control arm with jack (slowly)
9. lowering spring will easily slide(yes slide) out since its a smaller size than stock
10. take off isos and replace with electical tape
11. place spring back in place do the opposite of what you just did
that is how i did mine took me a very very short time to do and i was even taking my time and i recleaned the springs and other small areas under there as well....i think it took me 45 mins per side with cleaning and the taping of the springs...its hot out there so bring a drink...good luck!
fiveoho
1,958
TN
Jul 19, 2010
  • Jul 19, 2010
i too swapped over to h&r ss springs. after a couple of months of driving, i decided the front needed to be lower. pulled both the top and bottom isolators on the front springs only. spent $5 on a bicycle inner tube and wrapped all the pigtails. netted me about another 1/2" and no squeaks. now i have the exact slight rake stance i wanted.
N
SOLD FOR SALE: H&R Super Sport FRONT springs only, 79-93 Mustang, 51650.77 F
  • nfilut43
  • Nov 2, 2026
  • Suspension Parts
Suspension Parts Nov 10, 2026
nfilut43
N
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
J
What's it Worth? Cobra IRS
  • johnnyj331
  • Aug 25, 2025
  • What is it Worth?!?!?
What is it Worth?!?!? Aug 25, 2025
