- Feb 4, 2004
- 516
- 0
- 16
I put up a photo a while back on a post . I was asked to take some photos before I painted my mods. So I did.
Photo 1 .... Is of what I do to the stock style perch. A washer gets welded in place to hold the 2" hole saw that makes the cut. The piece of 2" seamless tubing is on the side.
Photo 2 ... Is of all the parts in one spot. The main shaft, whats left of the stock perch sheet metal, the 2" sleeve and R14-2RS bearings.
Photo 3 ... The shaft has to be this clean before the bearings will slide on. I displaced metal with a punch to hold the bearings in place. I don't think cutting into the shaft for E clips, or welding on the shaft is a good idea.
Photo 4 ... Taking the shaft out without beating the snot out of it is the trick here. I put it in the BFvise, cut a groove in the outer shell and peal it open like a banana, then use a old bread knife to take the rubber off. The new replacement perch bushings are made of vulcanized rubber. Strong stuff.
John
John
