  • SN95 4.6L Mustang Tech
Spring rates
  • Thread starter Thread starter '13_ImpactBlue_GT
  • Start date Start date Jul 4, 2005
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Where the men are men and the sheep are nervous
Jul 4, 2005
  • Jul 4, 2005
Can anyone explain what the different spring rates mean?
YardSpecial
2,664
MT
Jul 4, 2005
  • Jul 4, 2005
higher the number the stiffer the spring
Stiffer = better handling to a point
Note: Stock Mustangs have a spring rate of approximately 420 lb/in front and 200 lb/in rear
http://www.maximummotorsports.com/HRsprings.asp
I run the H&R SS springs on my vert, ride is WAY better then stock and handles like on rails.
Progressive is the only way to go on a street car, softer for the first 1" or so the gets stiffer for there......
RedBullitt
462
Morgantown WV
Jul 4, 2005
  • Jul 4, 2005
softer ones give you better ride quality and better weight transfer for launching. you will spin less off the line generally.
you basically have to chose between really good handling and really good launching. either drag or twisties basically. progressive springs have variable spring rate, the more you compress, it changes, giving a better ride.
non progressive springs are the same the whole way.
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Jul 4, 2005
  • Jul 4, 2005
Ok, so if I used aftermarket springs would they ruin the factory shocks and struts?
YardSpecial
2,664
MT
Jul 4, 2005
  • Jul 4, 2005
no
They just can not keep up, so they fade.
I running mine because of the low miles on my vert, D-Spec's go on at 60K miles.......(have 30K now)
squares98
852
Orange,ca
Jul 4, 2005
  • Jul 4, 2005
linear springs give more predictable handling, progressives are not hot
YardSpecial
2,664
MT
Jul 4, 2005
  • Jul 4, 2005
Um, Ok
Linear = kidney belt
jrc_03_gt
786
  • Jul 4, 2005
I was thinking about getting some springs. Not sure what I want though. Maybe the bullit package .
squares98
852
Orange,ca
Jul 5, 2005
  • Jul 5, 2005
Cavallo said:
Um, Ok
Ive had the pro kit and sportlines, and I like the behavior of the car, and ride with sportlines. JM observation
Sick96Stang
621
Gilbert, Arizona
Jul 5, 2005
#10
  • Jul 5, 2005
  • #10
I've got H&R sports and I have no complaints about them.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Code p0204
  • 04blckstang
  • Nov 23, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
Ebay Lowering springs
  • Canyonred86
  • Aug 28, 2026
Qtrhrse23
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
W
2.3l cooling fan questions
  • waxman
  • Jun 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 27, 2026
AeroCoupe
