  • 1994 - 1995 Specific Tech
Spring removal.
  • Thread starter Thread starter ThePumpkin
  • Start date Start date Mar 6, 2009
ThePumpkin
55
Missouri
Mar 6, 2009
  • Mar 6, 2009
Can someone give me step by step instructions on the removal and replacement of the springs.
I'm doing the front first so lets start with that.
Anyone have pictures of the procedure?
It looks relatively easy, I just want to make sure before I mess something up.
Thanks in advance.
SublimeRT
230
Clarksville, TN
Mar 6, 2009
  • Mar 6, 2009
I could tell you step by step, but I'm pretty positive there are plenty of spring install write-ups online that could be found in a google search.
Here ya go.
http://www.stangnet.com/tech/spring.html
http://www.americanmuscle.com/h-r-ss-spring-96-04-install.html
http://www.mustangevolution.com/articles/200716/
http://mustangworld.com/ourpics/fcar/steedaspring1.htm
http://mustangworld.com/ourpics/fcar/spring1.htm
ThePumpkin
55
Missouri
Mar 6, 2009
  • Mar 6, 2009
Thanks!
I spent about a half hour looking for the specifics on the forums with no luck.
Thats EXACTLY what I need.
I'll put some pictures up when Im done!
Thanks.
OrangeMustangGt
1,976
Cape Cod, MA
Mar 7, 2009
  • Mar 7, 2009
good luck! Nice thing is you dont need a spring compressor, they literally just push in!
ThePumpkin
55
Missouri
Mar 8, 2009
  • Mar 8, 2009
We used a compressor to get the stock spring out. It may have been unnecessary, but it worked and I had all the time in the world.
Although we are having trouble getting the new spring in. The A arm is all the way down, we have legit space. But the spring wont just "pop" into the allotted circles its supposed to sit in. I've tried pushing, prying, kicking, jacking, lubing, hammering, from every angle I could fit in. We had four or five guys come by today... nobody could get the spring in. Whats the deal? In all the instructions it never mentions the newer SHORTER spring having any trouble at all getting it.
Is there a little secret I dont know about?
The spring compressor would work here but the threaded stick is too long, making it worthless.
Why am I having such trouble? Getting the stock spring out was easy. Getting the new one in has yet to happen.
Any advice?
HISSIN50
34
129
Mar 8, 2009
  • Mar 8, 2009
You could shim the threaded stud so it doesnt bottom out (I've done Fox III springs this way -otherwise the threaded rod hits the frame before the spring is compressed).
Otherwise, the LCA bolts are nice and loose, right? I have Prokit springs, which are pretty tall for aftermarket springs, and they pop right in.
The alternate method is to disconnect the LCA bolts and remove them. Then reattach the ball joint. Your LCA is now pivoting on the fulcrum created by the strut. Put a good, large floor jack under the LCA. Put the spring in place in the perch. Then jack the LCA up and install the LCA bolts. If you want to read about this, it's referred to as the MFE method here and on the Corral. It's how I've done springs on most cars since I was a kid. You have to be real careful with the jack (and have a good, big jack. No 15 dollar specials) but it allows tall springs to be reinstalled because the pivot point (BJ) is so far from the spring (whereas the LCA bolts are too close to the spring).
Good luck.
drakesdad
961
Oregon OHIO
Mar 8, 2009
  • Mar 8, 2009
Good luck.
JT, that's exactly how I did the springs on the Blue V6 vert I had.....first time I did springs, (they were broken) so I replaced them with stock ones.......
95BlueStallion
My assy trans to myself
5,130
3,103
214
Cedar Rapids, Iowa
Mar 8, 2009
  • Mar 8, 2009
Good luck.
How hard is it to realign the LCA bolts once you are trying to put it back together? Im going to be doing spring work soon and would rather not deal with unbolting the whole stut and bj assembly.
HISSIN50
34
129
Mar 8, 2009
  • Mar 8, 2009
It can be a PITA. On Fox III's, when you first start to jack the LCA back up, the jack can really want to push away. Some people have put a big piece of wood under the jack's chassis so the jack's wheels cant roll.
The first time I ever did this method on a stang, it took me about 45 mins for the first side. Then I knew how it went and the second side took me 15 mins from start to finish.
If you can guess where the LCA needs to go, it helps a lot. I align things and do a dry run with no spring. Then lower the jack saddle, add the spring, and get it really close (if the jack doesnt move).
For the bolts, one side will line up before the other, so I just jack it till the first side is ready for a bolt (a screwdriver to help align the hole makes it easy), insert the bolt, start the nut, and then move to the other side (which usually requires a fraction of a jack pump to align).
ThePumpkin
55
Missouri
Mar 8, 2009
#10
  • Mar 8, 2009
  • #10
Got it done. for some reason, the A arm wasn't dropping down as far as it could go. I just pressed on it with my foot. The spring didn't exactly go in easy but we got it. The other side was a LOT easier. I think I decided to do the wrong side first. We haven't got the rear springs in yet.
Im going to save that for nicer weather.
Thanks for the help.
I'll put some pictures up in a bit.
ThePumpkin
55
Missouri
Mar 8, 2009
#11
  • Mar 8, 2009
  • #11
ThePumpkin
55
Missouri
Mar 8, 2009
#12
  • Mar 8, 2009
  • #12
94-302-vert
1,947
NE CT
Mar 9, 2009
#13
  • Mar 9, 2009
  • #13
Lowering the car has to be one of the cheapest and most rewarding mods there is huh?
drakesdad
961
Oregon OHIO
Mar 9, 2009
#14
  • Mar 9, 2009
  • #14
ThePumpkin said:
I spy the wonder bar........I so loved using the "pickle" fork.........
Car looks great !
99FiveOh
2,051
20
99
J-Ville, FL
Mar 9, 2009
#15
  • Mar 9, 2009
  • #15
What I don't spy is a nice long pry bar, maybe it was out of the shot or something. Def. worth having around for this type of work.
Looks good though, now lets see you put the rears in!
HISSIN50
34
129
Mar 9, 2009
#16
  • Mar 9, 2009
  • #16
The rears will be much easier and faster.
ThePumpkin
55
Missouri
Mar 9, 2009
#17
  • Mar 9, 2009
  • #17
Thats what I hear.
I'm hopefully going to do it tomorrow, but it might T-storm
Im beginning to like the look of the stance with only the fronts swapped.
Maybe an inch lower in the back would be prime
Too bad I got 2" all the way around.
No rubbing issues so far
I can almost guarantee I will in the back though.
i guess we'll see.
Anyone else running a 2 inch drop all the way around?
95BlueStallion
5,130
3,103
214
Cedar Rapids, Iowa
Mar 9, 2009
#18
  • Mar 9, 2009
  • #18
What are you running for caster/camber plates and shocks/struts?
Hef5.0weisen
20+ Year Stangneter
Mar 5, 2004
574
NorthWest Florida
Mar 9, 2009
#19
  • Mar 9, 2009
  • #19
Definently think about some cc plates, soon. The inboard edge of your front tires will get chewed up quick. And, if you're going that far, get the ball jonts and tie rod ends, then get a good alignment. Do it yourself, it's some work, but do-able.
OrangeMustangGt
1,976
Cape Cod, MA
Mar 10, 2009
#20
  • Mar 10, 2009
  • #20
Im amazed you had so much trouble. For me, the stock springs came out a little harder, but aftermarket shorter ones always pushed right in. You know, after looking at your picture I think i know why u had so much trouble. You should have jacked the entire front end of the car off the ground and used jackstands....I bet the sway bar was holding the a-arm from dropping all the way! same thing for the rear!
I
Removing NX NOS kit?
  • ironhorsewayne
  • Jun 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 8, 2026
squeak93
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Paint and Body Frame rail dimensions
  • keel
  • Jan 30, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 13, 2026
keel
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
Fox Full set of seats in the back of a hatch
  • keel
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2026
keel
