  • SN95 4.6L Mustang Tech
Spun Bearing, when does it "Knock"
  • Thread starter Thread starter Rickyll7
  • Start date Start date Sep 23, 2006
First Prev 2 of 2
98armygt
33
#21
  • Oct 25, 2006
  • #21
im gonna tear mine down this weekend hopefully and start cleaning all of that crap out. see what i got jacked up in this thing.
Batterystang
126
North Carolina
Nov 25, 2006
#22
  • Nov 25, 2006
  • #22
I have that exact same sound coming from my motor. I'm just wondering how I can determine the problem (valvetrain or bearing). What can I do to with the motor completely together? Or am I gonna have to pull the head and take a look?
I swear I can work on a pushrod motor, but these things.. ughh
Kurgan
3,028
Palm Beach Gardens, FL
Nov 27, 2006
#23
  • Nov 27, 2006
  • #23
Best bet to locate the problem is with a mechanic's stethoscope. Make sure you listen to the bottom part of the motor. Put the scope on the main bolts sticking horizontally out of the side of the block right above the oil pan when checking for rod knock.
For checking valvetrain, put the scope on the timing cover bolts going into the cylinder heads or the bolts that hold down the intake manifold. You can even remove the valve covers and run the engine, but the cam gears and chains will sling oil all over the place and make a mess so be prepared for that.
A rod knock can sound like the noise is coming from the valvetrain. And it's even louder if you pull off the valve covers. You'll think you have a collapsed lifter or chain tensioner from the way it sounds and how loud it is without the valve covers on. Make sure you listen carefully to the bottom end of the engine to be sure.
You won't be able to see if you've got a spun rod bearing by pulling your heads. You need to drop the oil pan to visually inspect for a spun rod bearing.
Batterystang
126
North Carolina
Nov 28, 2006
#24
  • Nov 28, 2006
  • #24
lol I know how to work on cars but i appreciate the help (i guess i did post it like I knew nothin, oh well)
just seeing if there is any other tricks out there that i may not know, especially with this damn motor
Kurgan
3,028
Nov 28, 2006
#25
  • Nov 28, 2006
  • #25
Besides dropping the oil pan or taking the motor apart, it's tough to verify for certain you've spun a rod bearing besides judging what an abnormal sound in the engine is by ear or even with a stethoscope.
First Prev 2 of 2
2001 SVT Cobra slow return to idle speed
  • phil2001svt
  • Oct 21, 2026
  • SVT Tech Forum
SVT Tech Forum Nov 2, 2026
phil2001svt
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
01 GT KNOCK AND NO IDLE FIXED!!
  • Scwhitten
  • Apr 27, 2025
SN95 4.6L Mustang Tech Apr 27, 2025
Scwhitten
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
