Sputtering low end driving
  • Thread starter Thread starter mapoff
  • Start date Start date Apr 15, 2005
M
mapoff
Blacksburg, VA
Apr 15, 2005
  • Apr 15, 2005
First of all, thank you for taking YOUR time to help another enthusist.
Problem: When driving under 2k rpms steady the car sputters as if pressing and releasing the pedal rapidly. Kind of a intermit jerky ride. This problem 99% of the time happens with "spout" in. No advance timing, fine 99%
What I've Done: steady fuel pressure, timing 10*btc, new plugs, new wires, new module, maf is good, new tps, new o2 sensors, 93 octane, no codes, rst computer. This is killing me. No one in 5 years and 3 mechanics figured out without me spending $1000. they all want to try a diff computer because its too much to t/s deeper.
New discovery: Disconnected the tps. Check engine light comes on(duh) but does not hesitate. Plug is and it stutters. my tps is at .97 volts at idle. I like doing things right. If i have to unplug it i think that is still going to hurt my mileage which i can't afford. You all are geniuses and i'm hoping someone can save my insanity.
HISSIN50
34
129
Apr 15, 2005
  • Apr 15, 2005
the first two things i usually recommend are checking the TPS and plug wires.
how is the range on the TPS? do you have a dead spot between 1-2 volts (or anywhere else)? an analog VOM works well for checking it out.
good luck.
N
nidyanazo
Banned
Mar 30, 2005
149
805 dawg
Apr 15, 2005
  • Apr 15, 2005
Dont run 93 fuel with timing set at 10*btdc. 87 will be just fine. Only go to 91 or 93 when your timing is ~14+* or so... Like Hissin said, your TPS may not be reading properly in the rpm range where you get the "studdering". If it's fine when the tps is disconnected, try another one.
M
mapoff
Blacksburg, VA
Apr 18, 2005
  • Apr 18, 2005
As I mentioned this is a brand new one and its doing the same thing. I was actually wrong about unplugging it. It still does the same thing just less when the tps is unplugged. Problem goes away even more when the "spout" is disconnected and there is no advance in timing. Problem is getting slowly worse and worse. Sounds like a sloppy timing chain to me but i'd hate to think how much money it would cost to have that replaced.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
T
  • Locked
1990 2.3L automatic - real bad engine sputtering
  • the_steve_randolph
  • Jun 13, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2024
the_steve_randolph
T
