  • SN95 4.6L Mustang Tech
Squeaky throwout bearing ?
  • Thread starter Thread starter Tim2002GT
  • Start date Start date Jan 30, 2007
1 of 2 Next Last
Tim2002GT
635
Tulsa, Oklahoma
Jan 30, 2007
  • Jan 30, 2007
Okay, this weekend I am going to be installing my prochamber and cat back. While I am down there, I was thinking about greasing my TOB. Just curious what type of lubricant works best to quiet a sqeaky TOB? I've been told to use lithium grease
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 30, 2007
  • Jan 30, 2007
You can either use lithium grease or moly assembly lube(molybdenum disulfide paste) on the fork groove of the T/O bearing. I personally think the moly lube works better and will last longer. You can also put some lithium grease on the input shaft in between the T/O bearing and the diaphram spring/pressure plate.
I made a little picture to show you where to put the moly lube in the groove where the clutch fork/lever sits. You can get the moly asembly lube at just about any auto parts store:
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 30, 2007
  • Jan 30, 2007
double post
Jsun3701
124
Virginia
Jan 30, 2007
  • Jan 30, 2007
White lithum grease, all day.
bakos24
I find there is nothing better than a tasty wiener
87
134
NE, OH
Jan 30, 2007
  • Jan 30, 2007
I tried lithium grease before and did not work . I would try the other stuff mentioned.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 30, 2007
  • Jan 30, 2007
Lithium grease is ok, but the moly lube is much better and lasts much longer. Unlike lithium grease, the moly lube chemically bonds itself to metal. It is the recommendation by most successful transmission gurus.
metroplex
405
SE MI
Jan 30, 2007
  • Jan 30, 2007
How do you access the TOB from outside the transmission?
BlueRuckus
204
Miami, FL
Jan 30, 2007
  • Jan 30, 2007
:Word: Subscribing.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jan 30, 2007
  • Jan 30, 2007
BlueRuckus said:
:Word: Subscribing.
Same here :SNSign:
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 30, 2007
#10
  • Jan 30, 2007
  • #10
It would be a lot easier to pull back the trans.
DTNODYA
831
#11
  • Jan 30, 2007
  • #11
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 30, 2007
#12
  • Jan 30, 2007
  • #12
DTNODYA said:
No need to scratch your head. Try fitting your hand through the clutch lever dustcover to get to the T/O bearing. I know mine won't.
Tim2002GT
635
Tulsa, Oklahoma
Jan 30, 2007
#13
  • Jan 30, 2007
  • #13
I was thinking there is some sort of plate on the side you can unbolt to access it. That might just be on the T5's or T45's
DTNODYA
831
#14
  • Jan 31, 2007
  • #14
What I was gettin' at is; How is it easy to pull the transmission back?
There's definitely no way to get your hand in the inspection hole. But I would think that if you unbolted the transmission, you may as well just replace the TOB.
T
thomas91169
I'd donkey punch my sister.
Aug 19, 2005
Modesto, CA
Jan 31, 2007
#15
  • Jan 31, 2007
  • #15
you have to pull the tranny. TOB's are cheap anyways, so why not replace it with OEM with the correct lubrication (like stated above, ive always used moly lube), instead of lubing up the old one only to have to do it again every 3000 miles
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 31, 2007
#16
  • Jan 31, 2007
  • #16
You can barely get your fingers up in there through the dust cover and lube the contact points between the back of the T/O bearing and the front of the clutch lever, but in my opinion you are best just to pull the tranny and replace the T/O bearing. The heavy duty FRPP T/O bearing works well. Use moly lube on the new T/O bearing.
Might as well replace the pivot stud and ball while you're there.
T
TripleBlk
312
Cape Canaveral FL
Jan 31, 2007
#17
  • Jan 31, 2007
  • #17
Do a search for how I fixed the TOB squeak. 20 minutes and 3 bucks for some Lithium grease. And you don't have to pull the freaking tranny . Sheesh - what do you have to lose ? Some of these "helpful hinters" love to spend other's time and money.
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jan 31, 2007
#18
  • Jan 31, 2007
  • #18
link?
Tim2002GT
635
Tulsa, Oklahoma
Jan 31, 2007
#19
  • Jan 31, 2007
  • #19
HoustonGT said:
link?
:Word: :SNSign:
T
TripleBlk
312
Cape Canaveral FL
Jan 31, 2007
#20
  • Jan 31, 2007
  • #20
aarrghh they removed my post - used to be in a tech sticky ...
Anyhow, jack up the car and crawl under the trans. In the front,slightly toward the driver's side, you will see a "tin" cover. Remove the 10mm retaining bolt and remove the cover. Shine a good flashlight up in there, and spray the lithium around the TOB and the shaft leading to it. Don't worry about the clutch so much - it faces the flywheel. Just be as accurate with the lube as possible. Button the cover back up and done. Then test drive.
I use the good lithium grease - I think Ace is where I got it...
1 of 2 Next Last
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • Gulftown980x
  • Jul 29, 2026
squeak93
L
New here from Maine
  • lobster
  • Mar 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 5, 2026
lobster
L
Am I crazy? Dad looking to buy 69 as daily
  • stonerCPA
  • Oct 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 18, 2026
nickyb
