F foxstang9050 New Member Aug 23, 2005 158 0 0 El Doarado Hills, CA Mar 19, 2006 #1 Mar 19, 2006 #1 This actually isnt about my mustang 5.0 its about my 97 Explorer 5.0... but im have some bad squealin comin fomr the belt and pullies.. just chekin to make sure but if im not mistaken that just means the belts loose right??
Rynb15 Member Nov 21, 2005 132 2 18 Mar 19, 2006 #2 Mar 19, 2006 #2 should be. Does it squeel nonstop?
troyGT03 New Member Feb 22, 2004 278 0 0 too close to memphis,tn Mar 19, 2006 #3 Mar 19, 2006 #3 are you sure that you dont have an accessory or idler pulley locking up or it is it just a little squeal?
F foxstang9050 New Member Aug 23, 2005 158 0 0 El Doarado Hills, CA Mar 19, 2006 #4 Mar 19, 2006 #4 Constant squealing.... almost souds like i gotta loud turbo
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Mar 19, 2006 #5 Mar 19, 2006 #5 Based on the little info, I think Troy is on track. Look for a pulley that has a bearing going south. A mechanic's stethoscope works well for finding noises like that (be real careful around heated, moving engine components). Tensioner and idler pulleys (if applicable) are places I look first. Good luck.
