  • SN95 4.6L Mustang Tech
Squeeling 99 GT
  • Thread starter Thread starter dmontzsta
  • Start date Start date Apr 18, 2006
dmontzsta
111
SoCal
Apr 18, 2006
  • Apr 18, 2006
My car has new rotors and pads, but for some reason it squeeks, not even when you are on the brakes. If I am coasting or accelerating from 5mph-20mph there is a squeeking coming from them, any idea what would cause this? I am stumped. When they are squeeking, I can tap the brake and it will stop while I am on the brake.
javsvt
27
Westchester County NY
Apr 18, 2006
  • Apr 18, 2006
Maybe the rotors or brakes got something on them. Some particles or even grease would make it squeal. Spray some brake clean on the rotors, see if that helps.
Brute03
232
  • Apr 18, 2006
my right front wheel just started doing this as well. the pads are still good but the strange thing is it only does it when i turn to the right and it goes away when i touch the brakes
R
rconaway
1,415
Phoenix, Az.
Apr 19, 2006
  • Apr 19, 2006
Did you rebuild the calipers? Did you use stock rotors/pads?
Mach1Run
333
Wylie, Texas
Apr 20, 2006
  • Apr 20, 2006
my mach does it too, both the fronts. Guys at the local shop said it was common with brakes that have a floating pad. Have done much follow up research yet so everything past "it's pretty common .." is greek to me. Thinking about puting on some of the anti squeek stuff if I can get motivated enough to pull the pads off the front myself.
R
rconaway
1,415
Phoenix, Az.
Apr 20, 2006
  • Apr 20, 2006
Depending on which pads you have, it might be a good idea to seat them. Take the car up to about 80 mph and then hammer the brakes. Don't let them lock up. Go down to about 20, then do it again. After 4 or 5 of those, they should stop squealing.
I have that problem with new brakes but I'm using powerslot rotors and SBS race pad. A few stops from 130+mph and they stop squealing.
BlackenedSVT
1,841
New Jersey
Apr 20, 2006
  • Apr 20, 2006
Holy christ LOL well that sure isn't the "by the book" way on how to correct this problem.
Try taking the pads off, and making sure no grease is on them, and maybe even rough the pads up a little with some sand paper to make sure no grease became inbedded into the pads. Then try greasing up the contact points on the outside of the pad and the caliper piston.
Then check to make sure hte splash shield behind the rotor is not contacting the rotor at all, especially while turning the wheels.
Loud/Squeeky brakes should not be accepted as a "common" problem. The only common thing about it is that some low priced cheap aftermaket brake pads have been known to squeel, but there isn't anything you can do about that except get differnet pads. But good pads should not be making constant noise. Did the car roll off the factory line making brake squeeling down the street? Dont think so
R
rconaway
1,415
Phoenix, Az.
Apr 20, 2006
  • Apr 20, 2006
That goes back to my original question, which brakes does he have? Since that was never mentioned, I made an assumption. That is the way you seat Baer brakes and other performance pad combinations. You need to embed some of the rotor material into the pad and that is the process. If they are just stock brakes, then you would be correct.
BTW, the 130+ reference was actually made on the track this week down the straight at Firebird and damned if those brakes didn't quit squealing on the street after that.
KronicRacer
502
puttering around Ft Lauderdale, FL
Jun 27, 2006
  • Jun 27, 2006
well im having the same exact problem with my new baer rear brakes. in right handers the driver side rear is squealing like a mofo. the shop that installed it is telling me that its a spline issue. now im gonna take it in to the mustang specialties shop since they are an authorized baer dealer to make heads or tails of this mess.
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
L
05GT brakes on a 98GT?
  • lparsons42
  • Sep 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2025
lparsons42
L
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 18, 2026
TPony
