Don't use the outhouse with Mike or you might get something else tweaked.Dan_Soprano said:I plan on getting my tune tweaked that day also..........
No. I don't want to pick up the mess afterwards.Dan_Soprano said:you get the big brown truck airborn?
Just making Mike nervous. Its good for a laugh.Dan_Soprano said:you know what I mean dick!!
i'd be cool though!gaslight said:No. I don't want to pick up the mess afterwards.
gaslight said:Bilsteins are not cheap but are supposed to be great shocks and last a long time. You could always go el cheapo with Monroe. Some like the Monroe shocks especially for the price.
Go COIL OVER! Thats what I want.
gaslight said:Remove digit from anus and insert in your mouth.![]()
I tried the link but couldn't connect.
whitehorseupnorth said:Looks like an oil pan gasket or some where higher up. Check the bolts like Dan said seee what happens.
I thought you have the adjuster installed. I'am not sure what your refering to.
Dan_Soprano said:Looks like either the pan is leaking, or the oil press. sending unit is leaking. no biggy either way. Just tighten the bolts on the pan up and see what happens.
Dan_Soprano said:i talked to pete and he said he will be tuning that day. It may be before or after the main group goes. I plan on getting my tune tweaked that day also..........
Badstang00 said:Any thoughts on this guys? Should I clean it up before I put my wheels back on?
nice! What time?Striped5.0 said:Tonight on PINKS
DOMESTICS VS IMPORTS !!!!!!!!!!!!!!!
I would have gone with the QA1s. When I talked to Denny, he said some racers were having problems with the Strange pieces lasting. After a long trip they would open the trailer to find the Strange ones leaking. Not trying to burst your bubble. Hopefully they work great for you.whitehorseupnorth said:I got some 10 way Strange Engineering shocks and struts comming.
I thought you had those sub's welded in...(*cough* sig)gaslight said:I would have gone with the QA1s. When I talked to Denny, he said some racers were having problems with the Strange pieces lasting. After a long trip they would open the trailer to find the Strange ones leaking. Not trying to burst your bubble. Hopefully they work great for you.
