North East SSoM Members!!!
Glad I could help. That $hit is gonna be very loud!!!
haha I know, I just hope its not to bad, if it is I can always get the regular magnaflow mufflers but I figured Id try something different. Could always put cats on it if its to loud as well.
You up for putting that on next friday or saturday depending on when you have free time? It should be here before then.
You only need a rollbar for 11.49 or faster.
I just thought that I once read that if you had a roll bar you needed the 5 point harness. Nothing to do with the speed just the fact that you have a roll bar. I could be wrong that is why I was asking if tech said anything. Couldn't find the info on the NED website like they used to have. Would have to consult a NHRA rule book.
Larry
I would start looking at various bearings. Like the drive shaft U joint or a possible wheel bearing on the front or rear axel shaft.
If you can grab the driveshaft at the joint and move it around slightly then that could be the cause. For the front wheel bearings, put in on jackstands and grab the wheel and try to move it side to side. THe wheel shouldn't have any give in it. If it has give it usually means it loose and in this case doesn't need to be tightened but replaced.
If that isn't it then try driving the car for a litte while then touch the rear axel near the brake backing plate and if one side is HOT then the bearing on that shaft is bad and needs to be replaced.
My flywheel is finally going to show up on wednesday. Placed that order on the 8th.
Took the car to get a alignement yesterday so that is taken care of. Doesn't idle for shat right now but still runs hard and the boost comes on strong.:D
if you have a bar...you don't need a 5 point harness....if you have a cage you must have a harness
Larry
Ok, thanks, I'm beginning to wonder if maybe the front brakes might not be releasing fully. Just seems that if it were coming from the driveline, I'd feel it in the shifter. Still haven't had a chance to check everything, maybe today.
Look here, it's IHRA, not NHRA sanctioned:
http://www.newenglanddragway.com/html/home.php?dest=handbook
So far, so good with my CF clutch. It feels a lot like the stocker as far as the pedal effort is concerned, maybe a little easier if anything. The clutch has not had too much chatter at all, and I can feel the clutch grab hard when it engages, while still having the ability to ride the clutch a bit. CF says to break it in for 500 miles without exceeding 3000 rpm's. As you can imagine, I have not seen WOT or any boost yet this year, so I feel like a crackhead who hasn't had his fix in awhile. I have 150 miles left to go, and then all hell is gonna break loose.
