You are talking about the rear end right?
feel the axel tube after it makes that noise. If one area is real hot compared to others than that could be the bad bearing. The bearing will be at the very end of the tube near the brakes. I had that happen many years ago. At first it made the noise on occasion then it became constant. The time it became constant I had to drive a ways to get home and that side of the axel was extremely hot.
Those bearings are easy to remove with the right tools. Slide hammer and a bearing puller. Both of which are free rentals at Auto Zone. I don't think the bearings are very much money either.
The u joints aren't tough either to replace. Just need 2 sockets and a large vice.
On another note I just busted someones balls in the classified section. He has 'cobra rear DICK brakes' for sale.
Both. The front end doesn't wiggle and the rear doesn't seem hot. But I didn't check the ends of the axle tubes. Just the spindle. Thanks for the tip. The noise is not intermittent. It just has to be driven while, then constant under same conditions that it didn't make the noise.
timeline
drove to CT on x-mas eve, rained, wore a hole in the steel brakeline chafed on exhaust, lost rear brakes w/ son and mother in car, sucked
went to fla on x-mas and my bro-in-law had line replaced, barely enough fluid left for fronts to work I was told.
drove back to ME on Jan 1st, no problems, besides the dr's on a slushy I95
PARKED THE F'N THING!!
Fired her back up to go to Shaws to clean IMRCs, and it starts making a noise at the higher speed, ie 80ish, on the way there, so no I didn't **** anything up cleaning it
Does it on the way back, but I was more concentrated on actual engine sounds then this annoyance. But I did lose about a pound of vaccuum. Gotta fix that line I showed you. Once I was sure I didn't **** up the engine, I gave it a few hot suppers. I actually noticed the improved power of cleaning the imrcs, shifts fine.
So, basically, it runs, shifts fine, just an annoying noise after it's been driven. I'm convinced it's either just tranny noise, or the brakes are completely f'd up.
Thats why I'm concentrating on things I can do here, in my dirt yard. I can't fix the ABS brakes if I **** them up. A trip to autozone for a "free" tool rental? OK, thats alright, I'll let it pass, you flatlander.
FWIW, I went over to mainland yestarday, left here at 7am, saw mom at rehab for an hour, got back in ferry line @ 11 am, spent the day moving up, after 4 loaded boats, I still didn't make it home. So camped out in the truck, and finally got home around 10:30 am this morning. No shower, no toothbrush, clothes or pillow or blanket. I friggin' hate summer jerks.
