stain removing techniques
  • Thread starter Thread starter luckythirteen13
  • Start date Start date Nov 1, 2005
L
luckythirteen13
648
Anaheim, CA
Nov 1, 2005
  • Nov 1, 2005
i have a couple of stains on my floor mats and i was wondering what are some good products/techniques for cleaning the stains out. i know there are a thousand products that i could try or i could have i professionaly done but i was hoping you guys could save me the time/money and give me some advice as to what works for you. i think the stains are dirt tracked in by my feet. its not oil or food.
thanks guys
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Nov 1, 2005
  • Nov 1, 2005
Are they love stains??? J/K I used tuff stuff its amazing stuff.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Nov 1, 2005
  • Nov 1, 2005
Some warm soapy water and then use a scrub brush...
if that doesn't work, just buy new floormats.
DW5.0L
172
Florida
Nov 1, 2005
  • Nov 1, 2005
I like ZEP high traffic carpet cleaner. It doesn't remove the color and is pretty good at getting rid of most stains. Spray it on and work it in with a rag or brush. Then wipe the stain away with a clean rag. Might have to do this a few times depending on the stain material.
steemin
201
Ft. Wayne Indiana
Nov 1, 2005
  • Nov 1, 2005
cleaning car mats
Hey finally a question that I have some expertise in..
(I own a couple of Stanley Steemer franchises)
Short of hiring a pro I suggest the following.
If you are dealing with just "dirt that you are tracking in"
the best method is as follows:
**Take the mats to a self serve car wash.
**If available clip the mats to the holders on the wall.
(if the clips are not available the floor will work)
**Using the soap setting spray them down good.
(starting at the top of the mat and work downward)
**Then turn to rinse and make really sure that you remove all of the soap.
**Hang to dry. You can also put fans on the mats to make them dry quicker.
99% of all carpet is made from synthetic materials. So the water will not hurt the carpet. With the above method you are actually flooding
(technical term titration)all of the foriegn materials out of the carpet.
The keys are not leaving a soapy residue in the carpet as it will resoil rapidly.
And not using a method that just grinds the soil deeper into the carpet without actually removing the dirt.
**If you encounter oil,grease or other petro based spots that the above method did not remove you can take a white towel and put a little lighter fluid or paint thinner onto the towel and then gently rub the stain starting from the outside of the spot working your way inward. Do not just pour the aforementioned products directly onto the carpet. After this step use the pressure wash method listed above.
Finally you might be surprised at how inexpensive a professional cleaning might be if you take your car to their shop. We typically only charge approx.
$60 for front and rear seats,carpet and mats on a car. Call around and ask.
Scott
Lyncher
434
  • Nov 1, 2005
I like a product called gonzo...its what my mom uses at the hostpital (she works in the er) ..it wil ltake out anything from what she has said...even blood out of sheets and stuff, and the ketchup i spill on the couch too!
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
Buying with a bad motor?
  • djj62478
  • Mar 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 11, 2026
TTSaleen
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
