Brake Lines
Basically you just take the old ones off and replace with the new SS lines. I put a set on my old 2000 GT (Russell). They were made to fit exactly like the old ones. The only "tip" I have is when you bleed the brakes, you start with the pass side rear, drivers side rear, pass side front, drivers side front. It is VERY important not to let the master cyl run low on fluid- if you introduce ait into the anti-lock unit, as I understand it, it will mean a trip to the dealer to bleed the system. If you aren't familiar with brake bleeding, it might be worth while to have a pro do it. I used a vacuum powered bleeder on mine, but not many people have one of these. Best of luck.
