STALL SPEED?
brake stall is what they go by when they advertize.if it says 3500 stall depending on your motor,they're saying it should hold around 3500.flash is sitting at idle in gear and flooring it,i had a 3500 that would hold 3500 but flash about 4100.
OIC. cuz i someone i know told me chock wheels, pull e-brake,hold hard on brake pedal, put in drive, and note the highest rpm it will go while floored.
about 1800 i hopped over both bricks and shot'em out the back
Does this mean at 1800rpms the converter lockd up and i took off.
when you hear brake stall, they are talking about on a tranny brake, not brake pedal or ebrake
if you have a manual valve body, the best way is 3rd gear about 15mph, floor it and whatever it flashes to, thats your stall
if you dont have a manual valve body, try 15mph in manual 2
