Stall under hard braking...
  • Thread starter Thread starter BlwnGazkit
  • Start date Start date Aug 25, 2007
BlwnGazkit
153
Richmond, VA
Aug 25, 2007
  • Aug 25, 2007
I'm having this problem where under hard braking my engine likes to stall out!
I'm not really sure what to look for here... I was going to check the fuel pressure and make sure that fuel wasn't sloshing around too much in the carb causing it to stall. But I'm not really sure if that's where I need to be looking.
Anyone have any pointers?
G
grego37
576
Fresno CA
Aug 25, 2007
  • Aug 25, 2007
check your float levels
zookeeper
3,415
63
109
Rogue River, Oregon
Aug 26, 2007
  • Aug 26, 2007
ditto
D
D.Hearne
11,730
south louisiana
Aug 26, 2007
  • Aug 26, 2007
If you've got a 4 bbl Holley, you need to install anti-slosh baffles in the bowl vent openings. Fuel pressure has nothing to do with it. The pressure needed to feed a carb is less than the pressure exerted by the floats against the needle/seat assembly. The baffles are made by holley and look like plastic whistles, they're about an inch long x 3/8" wide by 1/8" thick.
BlwnGazkit
153
Richmond, VA
Aug 26, 2007
  • Aug 26, 2007
It's actually a rebuilt Edelbrock. I rebuilt it recently and it was working fine... Guess I'll pull the top off and take another look at the float levels.
Should I be running a fuel pressure regulator? I'm not currently, never have in the past but it's been suggested to me. I'm just using an OEM fuel pump.
D
D.Hearne
11,730
south louisiana
Aug 26, 2007
  • Aug 26, 2007
You should need no regulator with an O.E. pump.
Iamdiffrnt
197
South of Detroit, MI
Aug 27, 2007
  • Aug 27, 2007
Just out of curiosity, what size cam are you running, and are you running a stock torque convertor?
BlwnGazkit
153
Richmond, VA
Aug 27, 2007
  • Aug 27, 2007
Converter is a 2700 stall converter and unfortunately I don't remember the cam specs, but no, it's not stock.
SoCalCruising
2,437
SoCal
Aug 27, 2007
  • Aug 27, 2007
Big cam and power assist brakes? If so, you could be pulling a lot of vacuum off the manifold for the brakes and losing signal to the carb. If you think this is plausible, a vacuum canister may help. Hydroboost brakes would be, perhaps, the best way to go, if you have power steering. In my case, I went back to mechanical brakes.
BlwnGazkit
153
Richmond, VA
Aug 27, 2007
#10
  • Aug 27, 2007
  • #10
I still have manual brakes actually. Lol, and no power steering so Hydro-Boost wouldn't be an option currently anyhow.
SoCalCruising
2,437
SoCal
Aug 28, 2007
#11
  • Aug 28, 2007
  • #11
Well, then: Nevermind.
BlwnGazkit
153
Richmond, VA
Aug 28, 2007
#12
  • Aug 28, 2007
  • #12
Thanks though
chepsk8
2,203
Easton, PA
Aug 28, 2007
#13
  • Aug 28, 2007
  • #13
We go through this subject alot with the Cobras, most of us run Holleys. The above float advice is dead on. Jet extenders have been tried as well.
Or, just stop braking so hard!
BlwnGazkit
153
Richmond, VA
Aug 28, 2007
#14
  • Aug 28, 2007
  • #14
Lol, gotta brake hard when you're coming up on a 90 degree right turn and still going 85....
I
98 Mustang GT dying
  • ItsMason
  • May 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 25, 2026
lenzgt
L
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
C
1967 Mustang 5.0 swapped shuddering/sputtering issues
  • Cro67
  • Sep 24, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 25, 2025
General karthief
