Stall upon Startup
  • Thread starter Thread starter sgw_88FoxGT
  • Start date Start date Mar 24, 2009
sgw_88FoxGT
43
  • Mar 24, 2009
So, when I start my car up it'll idle for five seconds and then the RPM drop and it stalls. Usually on the second time I start it it works fine. If I give it some gas right when it's about to stall it'll keep it from stalling and if the car's already warmed up and I start it it won't stall either. The only thing that's been going bad recently that I need to replace is my alternator but I don't that's it because all the electronics continue to work when it stalls.
Any ideas?
cenok is family
1,409
69
79
Norman, Ok
Mar 24, 2009
  • Mar 24, 2009
check your iac
sgw_88FoxGT
43
  • Mar 24, 2009
IAC is new. I'll check it again to make sure. When I get a chance I'll check the codes too.
66sprint6
131
Mar 24, 2009
  • Mar 24, 2009
Mines doin the same thing but every time I start it when warm. Mash your brakes and see if it makes a whooshing noise and stays runnin when you start it up next time. Found out my booster is bad and Im hopin that this new one will make it better.
Matt
sgw_88FoxGT
43
  • Mar 24, 2009
I just realized this should be in the tech forum. whoops
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Mar 24, 2009
  • Mar 24, 2009
1. Pull codes;
2. Check for vacuum leaks;
3. Remove/check/clean EGR valve;
4. Check TPS voltage;
5. Replace fuel filter (if not done within the past year or two);
6. "other"
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 24, 2009
  • Mar 24, 2009
See the "Surging Idle Checklist for help with all your idle/stall problems. Everything you need to find and fix idle problems is in there.
The first two posts contain all the updates to the fixes. At last count there were 24 possible causes and fixes for surging idle/stall problems. I continue to update it as more people post fixes or ask questions.
sgw_88FoxGT
43
  • Mar 29, 2009
I replaced spark plugs and had my mechanic clean the fuel lines and now the stalling doesn't happen anymore so it was probably one of those two. Thanks for the help guys.
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
G
Its starts then stalls
  • gray owl
  • Jan 22, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 25, 2026
gray owl
G
C
1967 Mustang 5.0 swapped shuddering/sputtering issues
  • Cro67
  • Sep 24, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 25, 2025
General karthief
M
3.8 start problems. New edge 2003
  • Mayk.i.
  • Oct 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 3, 2025
manicmechanic007
