Stalling issue
  • Thread starter Thread starter notched1
  • Start date Start date Jun 28, 2005
N
notched1
31
ontario,canada
Jun 28, 2005
  • Jun 28, 2005
Ideas? (only) On hotter days(35+c) in slower light to light traffic Ive had it (89lx) stall out like it was starving for gas. Go to restart and its like the cats are kicking/bucking like crazy. Let the car cool down a few and it goes away like nothing happened....Is this what considered a vapor lock or have something to do with the O2 sensors getting loaded up/overheated or ???
thanks 89
"Get that pos off the road" as quoted moments ago by import *** with 3 baby seats in the back of his sewing machine.
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Jun 28, 2005
  • Jun 28, 2005
Have you checked the codes to let the computer tell you where to begin looking? What type of mods do you have?
Stalling can be many problems... Sometimes it's as simple as changing the air filter
N
notched1
31
ontario,canada
Jun 28, 2005
  • Jun 28, 2005
Not yet. Filter(K&N) was just cleaned/oiled
Very basic bolt on mods. None fuel related.
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Jun 28, 2005
  • Jun 28, 2005
How is the electrical system on the car? Sometimes if the ECU doesn't get enough electricity then the car can stall.
Dumping the codes would only take 2 minutes and you only need a piece of 2" long wire to do it...
HISSIN50
34
129
Jun 29, 2005
  • Jun 29, 2005
Could be ignition (TFI). Does it restart immediately? How is FP at warm idle? There are a lot of possibilities. Stuff needs to be narrowed a bit. O2's would not be near the top of my list. Bad MAF perhaps.
Good luck.
bdog9seclx
113
atl
Jan 7, 2006
  • Jan 7, 2006
if u just cleaned your kn it is most likely the juice from it coated your maf sensor elements...use electric cleaner to clean it be careful thooo. u must take the black top off of the maf to get to it...can stress enuff careful....lemme know if it fixes it..
Black1987Stang
1,422
Jersey Shore
Jan 7, 2006
  • Jan 7, 2006
I was gonna say the same thing...clean the maf since the oil likes to get on the maf elements. and also to pull the codes
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 7, 2006
  • Jan 7, 2006
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
Progress Thread Black Beauty: '85 GT T-Top: Winter Is Coming
  • LiquidStangs
  • Jul 30, 2019
  • 2 3
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2019
LiquidStangs
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
93 5.0 Lx Stalls In The Summer
  • Ryu
  • Jun 22, 2015
Fox 5.0 Mustang Tech Sep 13, 2026
Ryu
Help! High Afr Warm Start
  • 65overheatin
  • Sep 7, 2016
3K
1965 - 1973 Classic Mustangs -General/Talk- Sep 8, 2016
MDF99
M
N
SOLD Supercharged 1989 SSP Coupe $13,500 obo
  • notchlubber
  • Jul 17, 2018
13K
Fox Body Mustangs For Sale (1979-93) May 28, 2020
notchlubber
N
