A problem just cropped up on my 95 GT. I don't think it has anything to do with the changes I just made to the car but here's what I just did.
New clutch
OR X-pipe
Removed smog (plugged vacuum lines)
Just recently the vehicle is stalling and won't keep idling if it get's hot. We've been having some warm weather lately and I've been driving the car now more than ever trying to break in the clutch.
At least three times this week once the engine was good and hot the car will stall when I come to a stop, will restart, but will immediate hunt for an idle and eventually stall.
The car does have some time on it (125k) but runs great when cool. It has a fresh tune up (plugs, cap, rotor, wires, fuel filter), and didn't blow any codes last time I checked. The cooling fan does work fine and the cooling system is in order.
So far all I've checked was the fuel pressure. I did it today when the wife came home and it was doing this same thing in the driveway. The fuel pressure was a steady 30psi while running, but once the engine started to stumble it would rise slightly and then become steady again.
I'm not exactly sure where to start, but heat related issues usually point to electrical items. Does anyone have a good starting point for me???
I also want to check the timing. I'm getting a lot of detonation (spark knock) when I really lay into it, and I noticed that someone before had marked a couple spots on the balancer. I want to know where it's at as well.
New clutch
OR X-pipe
), I can wind out 1st gear pretty well, but soon after I grab second it detonates pretty good, to the point where I have to either shift or let out. I realize regular unleaded has it's drawbacks, but if it was fuel I'd expect spark knock through out the whole range and not just when the engine is pulling in second gear.
