stalling
IEatRiceGT
150
MD
I have looked around and this seems to be a common problem: my 95 gt seems to stall out when it tries to idle(some of the time, other times its fine) and sometimes when I come to a stop it stalls out. I am away at college so I don't get to work on it often...my question is does this sound like my a/f needs a tweak or a leak/block somewhere?
--it has seemed to get worse after installing o/r h-pipe
Have you pulled codes?
Did you need a tune after your mods? It sounds kind of like the normal idle issue with mods. What is your idle setting normally? Have you cleaned the IAC recently?
Good luck.
It's not pulling any codes, it was tuned after all mods except o/r h-pipe by the previous owner using tweecer rt(he said it was only conservatively tuned however). My idle is normally about 1k, jumping w/ cams, but I plan on cleaning the IAC the next change I get
