Did Hci and maf swap car will start run and drive. When I push in the clutch to stop motor stalls. Hit the key and will fire right back up or pop the clutch. Did a code check and no codes are present. Any ideas for a fix.
You just unknowingly answered a question that has plagued me for years. I had no idea there was a VSS linked in with MAF cars. That would answer why the idle hangs while coasting and then settles when I stop, right?What did you do for the VSS input to the computer when you changed to mass air?
Bingo. That happens by design.You just unknowingly answered a question that has plagued me for years. I had no idea there was a VSS linked in with MAF cars. That would answer why the idle hangs while coasting and then settles when I stop, right?
and @Lscam580 VSS is vehicle speed sensor.
I'm new to this, what is a vss
