- Nov 20, 2003
- 15
- 0
- 0
Hey guys...quick question...
i have a 95 V6, standard shift tranny. I'm well aware of the head gasket issue on my model V6. But does this effect ALL of them, or just random ones... the reason for my question is because my car was running kinda funky...doggish...and cold air when i wanted heat...so i checked my oil, and my coolant...both were needed i added the coolant, and oil...that was about 2 or so weeks ago and it's been running fine, plenty of heat when needed, no noises, not doggish anymore. When i checked my oil, I did look for the signs that i've read about w/ a blown head gasket. I read look for coolant in the oil...it should be like milkyish. And I never have white smoke coming from my tail pipe.
My questions is, can that poor performance be chalked up to necessary maintence, or do those first symptoms i mentioned only occur with blown gaskets. I checked with the previous owner of my car (not original), and she said she never had the gasket replaced, was unsure if the owner before her did or not. I also check Ford's website, and Intellichoice, put in my VIN, and found no recalls on the head gasket....
someone...help...before its too late...
But those are unlikely.
I filled it up and the problem went away.
You shouldn't notice this until the temperature guage is all the way to the right, close to or over the "L" of "NORMAL". Did you notice the temperature guage rise up at all?
