  • 2.3L (N/A & Turbo) Tech
stang help!
  • Thread starter Thread starter Foxy2.3TC
  • Start date Start date Oct 8, 2008
Foxy2.3TC
51
  • Oct 8, 2008
so i just got my engine swapped out. did it myself with the help of my uncle now i have a question. since the car was dead and couldnt be run, the ebrake was set cuz it was on a hill. now that the car is drivable, the brake light is on and it feels like the ebrake is engaged even though the handle wont unlatch it. also, my brakes have no pressure until almost the floor, where they pick up and catch. any idea? my steering wheel has about 3 inches of play both ways before catching. any ideas there? all help is appreciated. thanks
2BADSTANGS
385
Colorado
Oct 9, 2008
  • Oct 9, 2008
As far as the brake situation, is your e-brake handle stuck in the on position? I had one of my e-brake cables lock up causing my rear brake to be on constantly, even though the handle is down. Have you blead your brakes? Also mabye check for vacuum leaks by the break booster. As far as your stearing play, if it's not tie rod ends (even if there bad, I wouldnt think you would have that much play.) I'm at a loss. Keep us posted!
Foxy2.3TC
51
  • Oct 9, 2008
where would i check to find if the cable locked up? and once i find it how do i fix it?
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Oct 9, 2008
  • Oct 9, 2008
Sounds like the e-brake siezed, best bet is to pull the rear drums and attempt to "unstick" everything.
Also that's probably what is causing your brake pedal to go almost to the floor.
stykthyn
5,232
2,652
223
gainesville
Oct 9, 2008
  • Oct 9, 2008
glad you got it running
fess40
292
Paris, Illinois
Oct 10, 2008
  • Oct 10, 2008
I second the siezed e-brake cable, I've had one stick on my '66. As for the steering play, check the rag joint in the steering shaft. Common problem and a cheap fix. Made a world of difference in mine.
Foxy2.3TC
51
  • Oct 15, 2008
got my ebrake unsiezed. my brake lines blew out so i ran new lines down and the brakes work now. and as for the play in the wheel, there was just too much p steering fluid now were ready to :Track: haha andd i got my new cold air intake rigged up and it sounds mean looks pretty good too
stykthyn
5,232
2,652
223
gainesville
Oct 17, 2008
  • Oct 17, 2008
pics or ban
Foxy2.3TC
51
  • Oct 21, 2008
ill try to get the exhaust up between classes. im at school now and i work right after so i might not get that up. as for the pics. ill put them up after the cobra kit is on adn it has been painted. it looks horrible now. theres clearcoat peeling everywhere from florida heat + parked 5 months straight even under a cover
A
Allard09
#10
  • Oct 23, 2008
  • #10
hey guys, i just bought a 1987 ford mustang 4 cyl fuel injected 5 spd standard (soon putting in a 5.0 when i get the cash). today i was driving and i noticed that in second and third gear when it gets between 2000 and 2500 rpms it seems to bog out and back fire a little bit until i hit around 3000 rpms then the power comes back... any ideas what this is caused by? it was running great until today. help much appreciated.
cheers, jordan
stykthyn
5,232
2,652
223
gainesville
Oct 24, 2008
#11
  • Oct 24, 2008
  • #11
might get more responses if you start your own thread.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
Can makes noises when driving poping
  • Creomod
  • Oct 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Creomod
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
Suspension 87 steering wheel slightly wobbles after new Rag joint install
  • R82148V
  • Jun 16, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
R82148V
