Been a long time since I've been on here. So just recently My car died. Thought I ran out of gas and the float was just stuck at 1/4 tank. So put some gas in then got it filled up and no problem. Then it happened again a tiny bit above 1/4 tank. Rinse and repeat from last time with same result. Now today I am running around town taking care of some things and the car just slowly dies out. I'm in gear pressing the gas and it seems like it's fighting to stay on but slowly just dies. I stop and wait about 20 min and start it up. Just dies right away. Try it again but press the gas while it's starting and it will go for a little bit then die again.
I have a full tank of gas in it so I would like to drop the tank after I try any suggestions since most everyone knows how much of a pain it is to drop a full tank. Also I was a bit low on oil. Filled it up tonight and drove it for about 20 min with no problem. But it has been 105 degrees so I'm not sure if the heat is a factor but it doesn't get hot and all fluids(now) are fine. I can't really think of anything else to give you guys to help right now. Any suggestions?
//edit
and I pulled codes and got nothing.
I also have a new fuel pump, new fuel filter, new MAS, new air filter.
//edit
