  • SN95 4.6L Mustang Tech
Stang stalling, need help
  • Thread starter Thread starter 95Cobra302
  • Start date Start date Feb 28, 2009
95Cobra302
394
Daytona Beach, FL
Feb 28, 2009
  • Feb 28, 2009
Wondering if you can help me. It's not my car, but my brothers 96 Mystic Cobra. When we are cruising along at like 45 mph or faster and we push on the brakes to slow the car down it just dies. It'll start right back up, and doesn't have any problems any other time. The car has been really well maintained and has only 50,000 miles. We are planning on changing the plugs and wires, even though they are only about 2 years old. I'm pretty stumped so if anyone has any ideas I will appreciate it.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 28, 2009
  • Feb 28, 2009
You'll probably have better luck in 4.6 Tech, since this is their area of specialty.
Moved to 4.6 Tech.
Bosko5.0
1,067
longwood, FL
Feb 28, 2009
  • Feb 28, 2009
When was the last time the fuel filter was changed.
95Cobra302
394
Daytona Beach, FL
Mar 1, 2009
  • Mar 1, 2009
3 days ago
trinity_gt
3,125
81
99
Canada
Mar 1, 2009
  • Mar 1, 2009
Can you be a bit more specific? When you are braking, you mean to a stop? The engine falls below idle speed, sputters and struggles for a bit before stalling? Or is there a more serious failure of the engine acting like someone turned the key off while at 45MPH with the brakes on?
If it's the former (i.e. coming to a stop, the engine sputters and stalls), I'd suspect the IAC (idle air control) system. You may also want to check for a vacuum leak after the MAF; cracked ducting, loose throttle body connection, stuck PCV valve etc. If it's related to 45MPH (steady cruise), you may also have some EGR valve involvement; if the valve is sticking, it mimics a vacuum leak.
95Cobra302
394
Daytona Beach, FL
Mar 1, 2009
  • Mar 1, 2009
Doesn't sputter or anything, just turns off like if you turn the key to the off position. Checked vacuum and got a reading of a steady 21-22HG.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
A
need help and advise
  • amps1956
  • Oct 14, 2025
  • Other Auto Tech
Other Auto Tech Oct 21, 2025
Mcmahst
