Hello people,
I have read this forum a few times and the info was a great help.
This time, I couldn't find a similar problem.
A little about my car. It's a 67 coupe. I am (will be, if I can get it to stay running) the second registered owner. The original owner was a guy who owned a body shop, and bought the car for his wife in 1967. It only has two options, a 289 V8, and power steering.
I bought it, in pieces, from his granson who was going to restore it. After I got it home, it took aprox 25 hours to put it together. I turned the key and it came to life. That was the best feeling, and not much but trouble since.
First, I couldn't keep a battery in it. So I found the problem to be the harness. (Corroded under the battery tray) Replaced the harness and the battery. Car runs again.
Then leaking in the rain. Found and repaired the heater cowel, with a cowel kit.
Then the voltage regulator, starter, and starter relay switch (on the shock tower) went, and all were replaced.
NOW, the car won't start.
I turn the key and get one slight click and then nothing.
I checked all the grounds (that I could find) and still the same thing, one little click. I removed the positive cable from the starter relay and put it directly on the battery and the engine cranks like it wants to start, but I don't think I have any spark. (I didn't check yet.)
I was wondering if this sounds like it could be the ignition switch?
Has anyone had similar problems?
There isn't a balast resistor (like in the old Chrysler products), is there?
