starter acting up...help!!!
  • Thread starter Thread starter jmd2914
  • Start date Start date Sep 8, 2006
J
jmd2914
937
Napa, California
Sep 8, 2006
  • Sep 8, 2006
i swapped my control arms tonight and decided to put my cat back back on in the morning so i took it for a test drive and when i came back home the car wouldnt start. fuel pump primes i have spark starters just not working. would the vibrations from no catback screw with the starter?? I'm at my wits end here. help!!!!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 8, 2006
  • Sep 8, 2006
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
J
jmd2914
937
Napa, California
Sep 8, 2006
  • Sep 8, 2006
when i hammered on the starter cuz it seems like it was frozen it started. but then after that it wouldnt start even after hammering so we tried push starting the car and it started. so is the starter bad?
HISSIN50
34
129
Sep 8, 2006
  • Sep 8, 2006
See JR's list - it could be the starter or an electrical issue to the starter. Diagnose it to save cash on unneeded parts.
Good luck.
J
jmd2914
937
Napa, California
Sep 8, 2006
  • Sep 8, 2006
thanks guys, i checked the starter over and it turns out the lug had started to come loose so the connectoin wasnt good.....I'm an idiot....lol thanks again
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 8, 2006
  • Sep 8, 2006
Four ounces of diagnostic effort is worth at least 20 pounds of parts thrown willy-nilly at a problem...
J
jmd2914
937
Napa, California
Sep 8, 2006
  • Sep 8, 2006
very true
  • dan50
  • Jul 18, 2026
dan50
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
