Starter help needed now PLEASE!!!
MadMatt5oh
441
St Paul, MN
:shrug: I just put in a high torque mini starter in my car. It would respond when I turn the key. I noticed it has 3 posts. One that has a ground wire running into the starter body, one that has a spade type connection and one that Appears to be the positive terminal. I hooked the loop up to that.
What do I do?
for a mini starter you might need to hook the thick red wire to the positive side of your starter solenoid, and the small red one to the other side. the small red wire is the actuator, and it is what really engages it since there is always 12v going to the large red wire. hope it works for ya!
agreed - the thick red wire 89 speaks of: run it from the output of the stock solenoid to the spade connection spot on the new solenoid/starter (im guessing on this, but the spade should be the trigger or actuator, as said above).
good luck.
My starter did not come with any wiring. I am clueless.
So I am to go to my driver side fender and swap the thick red wire to the other side? And then move a thin red wire to the opposite side as well?
:bang: I think Im going to put the tempermental OEM one back in if I cant figure this out
good luck.
I have stock wiring for an 88. Can you guys break this down for me in Moron terms so I can understand? :(
I beleive the neg side of the starter solinoid has a ground wire running into the body of the starter. I have the starter wire on the positive side - I believe.
Do I need to get a wire and run it from the spade connection (on the starter solinoid) to somewhere else?
I am running out of time guys. Stangnets all I have right now
You may need a '93 spec solenoid with the longer stud to put the heavy gauge wire on. These starters run a hot from the battery to the starter as said above and use a smaller wire to actuate the starter's solenoid.
Jamie
Jamie is right on. ill toss more info out, as it sounds like you are a little lost. the stock solenoid has one hot-side terminal (with all the cables on it) and one switched side (only the large cable on it - cable goes to the starter in oem configuration).
now you have a second solenoid on your new mini starter. so disconnect the battery (should be already. to prevent shorts). if you can, move the single cable that is on the stock solenoid, to the other side (with all the other cables). this is where Jamie is saying you might need a newer model solenoid, to accomodate the additional terminal on the solenoid lug).
get some wire and connect one end to the now barren oem starter solenoid lug (you just took the cable off of it and moved the cable to the other side). run your wire to the new starter's solenoid. put it on the spade connector (might say 'activate' or trigger or something).
so now, operating wise: you turn the key to start. the interlock devices all work, juice goes to the thin wire on top of the oem starter solenoid. the solenoid switches, and sends juice down the wire you ran (from the once barren lug) to the new starter's solenoid. this switches the solenoid on the new starter. you have battery power hooked to it already (when you moved the single big cable on the oem solenoid to the other side with all the other cables). so it should start.
Jamie, et al, does this sound right? (i have not done one of these, so im using my [usually flawed. LOL] logic to try and help him out).
Hissin, thanks man! :nice: yup, Thats an extremely well detailed and unflawed instruction! Unfortunately, I got this info from a buddy I couldnt reach earlier. I bought the wire and connectors and soldered together a beauty. I snaked it through nice and factory like. I hooked everything up as I was supposed to and guess what?
The Goddamn thing doesnt work! The starter would spin but not engage the flywheel!
It seems I got screwed over on this starter. Oh well, at least I know how to do it :)
thanks for the kind words. :) sorry to hear the starter is not working right. IIRC, some of the mini starters require shims to ensure proper bendix engagement, but that does not sound like your problem.
i think you know what ya got to do - take it out and bench test it. maybe you can return or warranty it. let us know what happens.
good luck Matt.
I bought the starter from Midwestmustangs.net on Ebay. I was told it worked fine. It doesnt. You know the real bitch about this? I needed this starter a month ago! First thing I recieve from these guys is a late 80's CD changer! They take it back and I had to wait another week for this starter as my daily driven stangs starter is getting more and more tempermental!
And now I have to pay to ship it back! WTF! No refunds - just exchanges! UHHHGGG!
sorry to hear that, man. stories like that make me want to use Allerstart or PA Performance for that stuff. thanks for the heads up, and good luck.
you could get a 93 starter (mini version, from ford) and use it. the wiring should be the same as you have now. you could sell the one you get (i hate to see you be stuck waiting again, for something that may not work).
good luck and let us know how it goes.
