starter problems........AGIAN!!!
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
well when i start the car the starter want to keep trying to crank it and when i shut it off it still keep doing it. so i pulled the neg battery cable. i let it sit for about 30 min and hooked it back up and its still doin it. I taped the start and that did nothin. i checked at the wires and thier all tight. the starter is about 8 months old and the soleniod is about1 months old. What could this be??? Im stumped!!!
i had this problem when i first got the car and blew the starter to pieces, got a new battery and come to found out i was missing the neg battery cable to the fender wall.
Need help ASAP, i have plans with a chick and dont want to mess this up!!!!
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems. See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
In addition to the wise info posted already, a quick and dirty test is to: when it decides to keep cranking, pull the S-terminal off the solenoid (it is the thin wire on top of the solenoid). If the starter keeps going, that suggests a latched solenoid. If it stops, look for bad wiring to the solenoid (namely a shorted connection at the ignition switch itself).
Good luck.
Good luck.
ok i just tried to pull the lil wire(then one that just plugs on to it right???)it keep wanting to start. does that mean i need a new solenoid???
thanks everybody :SNSign:
im doing everything kinda quick cause it snowing outside and im doing this in the driveway:bang:
Sounds like a solenoid to me. If the car was cranked with a weak battery at some point recently, that can screw up the contacts in the solenoid (they kinda weld together during this situation) and sometimes the contacts are forever messed up (Jrichker can provide a technical explanation, I bet).
That is MHO anyhow.
Good luck.
That is MHO anyhow.
Good luck.
I had the same problem a while back.The starter would just scream after i tried to crank it over, it would keep on going after i turned key off also.I ended up buying a "few" starter solenoids and that didnt help either. I ended up getting a new battery and it solved the problem and its never happened since.Like Hissn50 stated the solenoid kind of welds itself due to the low charge of the battery.
