  • SN95 4.6L Mustang Tech
starter problems
  • Thread starter Thread starter 2fastnotch
  • Start date Start date Mar 4, 2011
2fastnotch
61
  • Mar 4, 2011
ok i have a 98 gt auto. Monday the starter went bad. So i replaced it after fighting with the 3rd bolt for hours i finally got it out. I replaced it i olnly put 2 of the bolts back in(i talked to a couple other people said if i left it out there wouldnt be a problem). So i start the car it makes a clanking noise when i shut it down so i started it up again rev'ed it and it made the same noise i thought it was the drive hanging up so i put another starter in it the noise on shut down wasnt there but i still had the noise when i went through the power band. So i was like eff it i got my original starter rebuilt now the noise is worse makes the noise all through the powerband and when i shut it down. Do i need to put the third bolt in it? im beyond frustrated with the car really close to donating it to purple heart.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Mar 4, 2011
  • Mar 4, 2011
The top bolt is difficult to get to. My first time took what seems like hours. Now it only takes minutes. The trick for me is to use a 13mm "flex" socket and a very long extension. Put a small amount of tape on the flex socket so that it does not flop over.
Go through the K-member. The socket will have to be guided onto the bolt by feel. Best if you have a buddy that can turn the ratchet handle once you are on the bolt.
It is easier if the exhaust has been disconnected.
Seriously, once you can visualize where the bolt is and give up on trying to actually "touch" the bolt, it is very do-able. The "flex" socket does help IMO.
A long extension works better than several smaller ones end to end. Less flex. More control. Remember that the socket will have to be guided home by feel.
I know there are tons of guys that leave the top bolt out without any issues. Personally, I never have.
With regards to the noise, are you positive the starter is fully seated?
Good luck. That top starter bolt is a PIA.
2fastnotch
61
  • Mar 4, 2011
i got the bolt out the starter seems to be rubbing on the flexplate.
1987stangman
684
24
  • Mar 4, 2011
Does the noise sound anything like it does when you hear people try to start their car when it's already running? sounds like the starter is not dis-engaging.
I left that 3rd bolt out when I put my new engine in and I have not had any issues.
2fastnotch
61
  • Mar 4, 2011
yes it kinda does but this is the third starter ive put in this car. and everytime it does it.
1987stangman
684
24
  • Mar 6, 2011
Never had to buy a new one for my 96'. I'm assuming they come with the solonoid?
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
M
2004 v8 convertible
  • Mikeycrownvicluver
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Feb 15, 2026
Mikeycrownvicluver
M
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
