Starter relay staying engaged
Sazxus
10
The other day I started the car turned the key back and the starter kept cranking.
I had to remove the battery cable to make it stop. i put it back on and it worked fine for a week, then one day it does it again. so i checked the ignition switch and it wasnt that, replaced the relay and it worked fine for a week or so then it started again. If its not the ignition or the relay what else might cause this problem?
89 mustang GT.
Either of the above are possible. It's easy to diagnose/test, but having your starter grinding away kinda sucks. If you have your starter cable (at the solenoid) set up in a way that it can be disconected easily and quickly (and safely), you can see if the bendix is hanging or if the solenoid is latching.
Good luck.
Remove the starter cable from the starter. Hook up a DVOM to measure the voltage at the starter cable. Have someone turn the key to the start position as if they were starting the car and then leave the key in the on position as if the car had started. You should only see voltage at the starter cable with the key in the start position. If you continue to see voltage after the key is placed in the run position then either your solenoid (relay) or ignition switch is bad. Remove the small wire (ignition switch) from the solenoid. If you still see 12v at the starter cable, then the solenoid is bad, if you do not see 12v at the starter cable after the ignition wire is removed from the solenoid, test to see if it has 12v. It should only have 12v with the key in the start position otherwise the ignition switch is bad. If you start the car and remove the starter cable from the solenoid and it is still grinding, then your starter bendix is bad.
