starter solenoid keeps frying
at the auto parts store it pulls up as a a starter selonoid its on the fender well i think i figured it out its a bad ground, casing on the wire looked good but inside was all messed up ,broken ,thanks anyway for the replys
I had the same problem. This old guy I know told me to add another ground to the neg. side of the battery. It worked for two years or so.
replaced the starter and i think its fixed the problem . must have had a short in the starter. it would start the car fine but kept pulling juice through the solenoid after it was started . tested the wire on top of the solenoid that plugs in after it was and it was still hot . its only supposed to be hot when starting
