starter solenoid question
  • Thread starter Thread starter gonzothegreat
  • Start date Start date Jan 8, 2006
gonzothegreat
421
London (uk)
Jan 8, 2006
  • Jan 8, 2006
I am planning to move my baterry to the trunk.
I got that box:
I also have a mini-starter.
What do I need to exactly to remove the starter solenoid, after searching thru that forum I've seen that you can do it. But cannot figure out the wiring
your help is much appreciated.
MCABOSS
245
BREMERTON, WASHINGTON
Jan 8, 2006
  • Jan 8, 2006
You don't need to move the solenoid to the trunk. Cars that came from the factory with the battery in the trunk (ie BOSS 429) keep the solenoid in the engine compartment. Just attach the negative to the trunk floor and run the positive cable to the solenoid in the engine compartment. Ed
gonzothegreat
421
London (uk)
Jan 8, 2006
  • Jan 8, 2006
I've read on several posts here, that you can remove the starter solenoid if you have a mini-starter. is that true?
68rustang
1,537
Cleveland, OH
Jan 8, 2006
  • Jan 8, 2006
If your "mini-starter" has an integrated solenoid then you do not need the fender mounted one any longer.
gonzothegreat
421
London (uk)
Jan 8, 2006
  • Jan 8, 2006
It's one from Pa-Performance I believe it does have one.
I am after a simple help on how to hook it up without the starte solenoid
68rustang
1,537
Cleveland, OH
Jan 9, 2006
  • Jan 9, 2006
I think edbert's site has some wiring diagrams.
gonzothegreat
421
London (uk)
Jan 9, 2006
  • Jan 9, 2006
thanks dude
Electrical Starter solenoid green wire?
  • 387lx
  • Jun 1, 2026
Fox 5.0 Mustang Tech Jun 2, 2026
AeroCoupe
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Electrical Mini-Starter Wiring
  • RekeHavoc
  • Jul 25, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
Mustang5L5
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Resolved Yellow Wire from Start Solenoid
  • Smoky5oh
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 30, 2025
Smoky5oh
