Starter spacers
  • Thread starter Thread starter my66coupe
  • Start date Start date May 31, 2004
M
my66coupe
1,134
Arizona fountain hills
May 31, 2004
  • May 31, 2004
My rebuilt motor, was getting bound up on my brand new starter after the install, I installed a spacer and it solved the noise that I was getting from the starter still being engaged. Currently I am getting a noise completely different that sounds almost like a baseball card hitting a bike spoke. I have posted about this already, and someone said it was either an exhaust leak or the fan maybe hitting something. I checked out both and found both to be incorrect. I am begginning to beleive that my starter is still getting bound up with the flexplate and making this new noise. My question is, would it be safe to run another spacer for the starter? thanks
Mike
P.S. Looking at my valvetrain components in my sig, would taller valve covers be needed? Right now Im running the 30 dollar chrome dress up ones that they sell at NAPA and Checker.....
12sec67
1,301
San Diego, Ca
May 31, 2004
  • May 31, 2004
i jhad to use 2 spacers on mine and everything worked fine.
also do you think it could be that you roller rockers could be hitting the low spot on the inside of the valve cover. i would pop the valve cover and look for any dents or scratches before messing with the starter again.
good luck!
Rich
M
my66coupe
1,134
Jun 3, 2004
  • Jun 3, 2004
Well I took an old set of valve covers and cut the top off, and ran the engine and the rockers have pleanty of clearance. I decided to give up on this problem for the day and decided I would replace my powersteering pump, It was rebuilt but still leaking and didnt affect my steering at all. Soo I replace the pump, and bam no more noise and my steering is back. The noise I heard was probabaly coming from the powersteering cylinder below the bellhousing....Which made me think it was the starter....Welp just need to get my timing down and my mixture right....Thanks again
Mike
P.S. would it be correct to set the mixture with a vacumm guage? Like when I get the highest reading of vacumm or is that only with timing?
R
Flex plate and starter issues
  • RJH46
  • Jun 24, 2025
  • Other Auto Tech
2K
Other Auto Tech Aug 19, 2025
nickyb
  • dan50
  • Jul 18, 2026
dan50
Starters suck. So does the aftermarket!
  • Blue Thunder
  • Apr 30, 2024
5K
1974 - 1978 Mustang II Talk & Tech May 13, 2024
Blue Thunder
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
