Starter won't disengage
  • Thread starter Thread starter Rapid
  • Start date Start date Oct 12, 2006
R
Rapid
297
Columbia, SC
Oct 12, 2006
  • Oct 12, 2006
65 289 w/C4 and new starter. There is a lot of noise after the car starts that is coming from the bell housing. I replaced the starter because the starter gear was not retracting but the noise is still there. The ring gear around the TC looks OK but it may be binding??
GoinBroke
109
Joliet, Il
Oct 12, 2006
  • Oct 12, 2006
Pull the inspection plate off the bottom of the bellhousing and make sure the starter gear is retracting as it should.
jcode68
892
Massachussetts
Oct 12, 2006
  • Oct 12, 2006
You may need to shim your starter a little, which is very common practice. Usually the manufacturer provides a spec for this and some even include a shim. My Power Master starter included shims.
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
1965 289 xmission
  • sctang
  • Nov 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 30, 2025
Mcmahst
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
