Starter
  • Thread starter Thread starter Mafia Mustang
  • Start date Start date Apr 24, 2008
M
Mafia Mustang
111
Arizona
Apr 24, 2008
  • Apr 24, 2008
Quick Question What would Cause a starter to start and keep trying to start? even when your no turning the key. This happens everyonce in a while.
Bullitt347
I have been doing it wrong this whole time
4,061
3,134
204
Middle of Maine
Apr 24, 2008
  • Apr 24, 2008
Starter solenoid is more than likely stuck.
5.0ina66
664
Ohio
Apr 24, 2008
  • Apr 24, 2008
I agree. I was going to say something different but then I realized this is an 88 so it has the conventional setup with a fender mounted solenoid. Beat the crap out of the solenoid with a hammer, I bet it won't act up again for a long time, and if it does, replace it. Fords have been doing the same crap since 1964 at least
mustangfan1990
505
Lenoir, North Carolina
Apr 24, 2008
  • Apr 24, 2008
Tap it with the handle of a screw driver DONT BEAT IT. If it keeps acting up replace it. Try running an extra ground wire to one or more of the bolts that hold on the Starter solenoid. The relays usualloy go bad due to a bad ground or not a strong enough ground
M
Mafia Mustang
111
Arizona
Apr 25, 2008
  • Apr 25, 2008
Ya I can try that I just got a new solenoid and it just started doing the same thing. you guys are probally right I just need to ground it better. Im just worried if it starts doing that and Im in a parking lot loll I will be S.O.L
82CapriRS
54
New Jersey
Apr 25, 2008
  • Apr 25, 2008
i've never had a problem like that from a solenoid. but it could be the bendix drive in the starter. they get stuck engaged an thats what happens. just my 2 cents
M
Mafia Mustang
111
Arizona
Apr 25, 2008
  • Apr 25, 2008
I been though 3 starters soo idk ..its possible tho. another thing that happens when I first start it it fires right up .but if I shut it off and go to restart it nothing just lights could these problems be related
82CapriRS
54
New Jersey
Apr 25, 2008
  • Apr 25, 2008
are you usin cheap starters? that could be the stuck engaged problem an when you shut it off an try to start it again can be bad ground on solenoid or just a bad solenoid
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
T
Electrical 1990 Vert starting/Solenoid issues
  • Tom77
  • Apr 18, 2025
Fox 5.0 Mustang Tech Apr 18, 2025
85GTStangGuy
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
